I am new to the forum and am resurrecting my '53 Commander Coupe that had not moved since 1989. Everything is working well except for the terrible driveshaft vibrations. I replace all motor mounts, u-joints, center carrier bearing, and center rubber mount bushings. I marked the shaft for phasing as I took it apart. When re-assembled, it was TERRIBLE! Could not drive above 30 mph. Took the car to a friends so we could put it on a lift and solve the problem (HA! HA!). Ultimately found that, even though I had marked it, the shafts were out of phase by 90 degrees. (a service bulletin in 1952 solved a problem with vibration on automatics by raising carrier 1/2" and putting shafts 90 degrees out of phase and continued practice from then on!) Changed the phasing and it improved somewhat. Now I started to check the alignment:
1. Horizontally, engine and pinion are parallel
2. With car on stands at ride height: engine down at rear 7.5 degrees; front shaft (with carrier in #1 holes) horizontal; rear shaft horizontal; pinion down at front 1 degree.
The above alignment does not seem right per normal driveshaft practice (pinion and engine/transmission parallel), but I don't see evidence where it was not that way from the factory.
I am having the driveshaft balance checked tomorrow.
If anyone out there can help me, I would appreciate it. I certainly could use a confirmation of the engine/pinion angles from someone with a stock driveline.
