Just an update on the adapter sleeves/bushings I'm getting made to adapt the Lark (smaller wheel) to the '69 Silver Hawk steering column. After I thought about it a while I figured that the original design for an adapter sleeve was too complex. Being a machinist I know how much time it takes and how much accuracy it would require to cut a semi-circle section out of the outside of the original sleeve. This "cut out" is shown in the first two pics as the .800" dimension:
the cost (time) to cut this semi-circle could be as mush as $75-$100 on top of the cost of cutting the ID and OD and length of the sleeve. My goal was to get the sleeve made for less than $100 to make this conversion something that others might want to try..
I came up with a simpler design so that someone else could easily get this done with less expense. I ordered two brass sleeves off of ebay. They only cost about $3.50/$4.00 each.
By buying these bushing, which are very close to the size they need to be, the machine shop will be able to easily and inexpensively cut them to the dimensions in this next pic:
The pic is courtesy of my daughter (future Silver Hawk Queen) who is taking an AutoCad class this summer.
I will no longer need a radial cut along the outside of the original sleeve. For those who might not have any idea how long it might take to cut these bushing to size....If I had a lathe I could cut them both in about 20 min. On the other hand, the semi-circular section would take more like 45 min to a hour and a half because of set-up time.
As you can see the outside of one sleeve will fit perfectly into the ID (1.155") of the other. The sleeve with the 1.032" ID (left side drawing) will press fit onto the Lark steering wheel hub. I'll heat it up with a propane torch and when it expands I'll slide it on the Lark hub. Once it cools it will never move or come off unless you reheat it to a high temperature.
The second sleeve (right side drawing) Will fit perfectly over the smaller sleeve but first I'll need to carefully measure and "hacksaw out" the portion where the signal switch will be. It should exactly match (within .010") the original slot that's currently in the '59 Silver Hawk hub as seen in this pic::.
Once I've removed the semi-circular section from the larger sleeve I'll either use two part epoxy to bond it to the smaller sleeve (using a stainless steel hose clamp) or I'll use my torch to braze it to the inner sleeve. Either way, it must me attached in such a way that it can't move!! The location of this slot dictates when you signal cancels in both directions so placement is critical!! It not a big deal because you can always heat the whole thing up and the epoxy will melt or, if it's brazed together, you can heat the whole thing up and the inner sleeve will expand (along with the outer sleeve) and can be relocated.
In 50 years no one else has tried this????
Comments...Suggestions...I'm flying blind here!!!!!
treblig
treblig
