Any tricks to tapping or otherwise fixing stripped timing gear cover bolts on my flathead 6?
Getting after a leak in the front and discovered two of the four bolts had been stripped and oil was coming out below the cover. There is not enough room between the flywheel and the bolt holes to fit a drill to tap.
Pulling the engine to remove the flywheel is a no-go and need some way to get some torque on the bolts to cinch the cover down. If I can't tap bigger bolts from the front can the holes be accessed from the other side if I drop the oil pan? Not something I look forward to given the other posts I've read so hoping someone has done this without removing parts.
