63 avanti water manifold housing casting number?
  • Cool/Heat: 63 avanti water manifold housing casting number?
    Does anyone know the casting number for a 63 avanti water pump housing? Also the proper intake casting number?
    thanks in advance
    hunter stanley
    If this is the engine you are/were planning on putting your Hawk, you do not want the Avanti water manifold. The Hawk/Lark manifold would be the better choice.
    You can easily tell a R1 intake manifold as it does not have the transfer slots whereas Hawk/Lark and R2 manifolds do.
    I will look in the morning for the casting numbers.
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
      The Thermostat Housing Mount Location is moved WAY off center to the Left on Avanti Water Manifolds.
        As near as I can make out, the casting number for the water manifold is 1555738.
        The casting number for the R1 intake manifold is 1557144.
        I suspect that non R1 intake manifolds have the same casting number as the only difference is the lack of transfer slots.
        78 Avanti RQB 2792
        64 Avanti R1 R5408
        63 Avanti R1 R4551
        63 Avanti R1 R2281
        62 GT Hawk V15949
        56 GH 6032504
        56 GH 6032588
          Ok thank you
          I’m gonna be looking at some r2 parts
          supposedly a block crank heads intake and manifold from a 63 r2 avanti in a week. Possibly gonna try and purchase.
          hunter stanley
            The only differences between R1 and R2, other than the S/C things, are heads and the intake manifold. The intake manifold is the same as other AFB Stude V8s.
            The block is the same for all full flow Studes (259 & 289). The crankshaft is the same for all full flow 289 Studes.
            78 Avanti RQB 2792
            64 Avanti R1 R5408
            63 Avanti R1 R4551
            63 Avanti R1 R2281
            62 GT Hawk V15949
            56 GH 6032504
            56 GH 6032588
              FWIW, the casting number for all Stude 289 long nose cranks is 1556444.
              78 Avanti RQB 2792
              64 Avanti R1 R5408
              63 Avanti R1 R4551
              63 Avanti R1 R2281
              62 GT Hawk V15949
              56 GH 6032504
              56 GH 6032588
                Avanti Water manifold
                Click image for larger version  Name:	IMG-6786.JPG Views:	0 Size:	107.0 KB ID:	1828986
                Click image for larger version  Name:	IMG-6787.jpg Views:	0 Size:	139.7 KB ID:	1828985
                Lark water manifold
                Click image for larger version  Name:	IMG-6784.jpg Views:	0 Size:	117.9 KB ID:	1828987
                Click image for larger version  Name:	IMG-6785.jpg Views:	0 Size:	96.9 KB ID:	1828983
                AFB Intake no transfer slot "1"
                Click image for larger version  Name:	IMG-6789.JPG Views:	0 Size:	83.1 KB ID:	1828982
                AFB Intake with transfer slot "2"
                Click image for larger version  Name:	IMG-6788.JPG Views:	0 Size:	114.8 KB ID:	1828989
                WCFB for comparison
                Click image for larger version  Name:	IMG-6790.JPG Views:	0 Size:	100.0 KB ID:	1828984
                  If there is someone who has an R2 water manifold and the supercharger and alternator brackets please write me at studepickups at optonline dot net.
                  thank you Ted Jensen
