I have a total front end rebuild pending for the 62GT, including upper & lower 'A' arm rubber bushings (last replaced Oct 2011). Also, as of yesterday, I discovered the 63GT needs lower 'A' arm bushings (last replaced Nov 2012). I am all for supporting our vendors, but considering the labor involved, want to use only the best bushings available, with NEW rubber. I am squeamish about the recent run of repro uppers, that supposedly have a taper instead of a shoulder that butts up against the hole in the 'A' arm. The older style uppers may still be around, but that means "older" rubber. So I have been looking into interchanges, with new rubber, that can be made to fit right.
In light of the above, today I ordered a set of brand 'X' upper and lower bushings. Pretty sure I can modify them to fit as good as OEM, using only a bench grinder and hack saw. Will not bother to say more, till I have successfully installed them. But it shouldn't be long, I plan to get to the 63GT ASAP, and have spare 'A' arms to work with.
