After my car overheated, i drained and changed the coolant as well as taking off some bad hoses. let's figure this out - what dirty looking compound could possibly be floating in the water?... that floating in the water?....Shown is one gallon of antifreeze out of the car after an overheat. A coolant leak down test was very slow but some was evident. This is out of a 1955 President State with a 259 v8. Compression test showed most everything in the 115-140 range. the lowest-115 was #3 where incidentally the hottest temperatures on the manifold shows up:240F vs about 180F for everything else. About the only other real symptom is a miss that starts when car is up to temp.- realize that could be a head valve somewhere- just didn't really show up on compression test. I am also wondering about cylinder head bolts- do I have to rip 'er apart to figure out what bolts I need? Can I reuse the bolts? Any advice in this regard would also be appreciated. thanks
Search Terms:259 V8, cylinder head , head bolts, compression test, coolant pressure test.
