Originally posted by cwsimpson
View Post
Anybody else think I need a new head gasket for '55 President?
Originally posted by colt45sa View PostThe compression test is awful. Did you do a wet leak down test as well as a dry test? If you have a "new" set of heads and a gasket set, why would you not simply swap the heads? I expect when you say "new" you mean new guides, valve grind, and seals. It doesn't get much better than that~! I'm surprised that the 'manual' would specify a 14# cap when a 1957 Chevrolet requires a 7# cap.
When I first saw that compression #, that's exactly what I thought! That's another reason why I was asking about head bolts. I did run a wet test on that same cylinder- very slight increase-indicating most of the problem is with the head , or gasket (increased to 120#). Maybe I just had to hear somebody say what you said and I'll find time to do it and do it right! Thanks for your input. (Idon't understand the different numbers on the caps either.)
