Someone gave me a 64 Daytona and it has two "T"s with a circle around each of them. Ones silver and one is red. It looks like a Studebaker emblem although the engine and chassis are all built up. The chassis is a "Fat man's" design. Anyone know what the Ts might mean?
What does the two circle Ts mean?
Originally posted by studefan View PostTwin Traction?(aka: positraction)
with all the mods done, you may want to check if the differential is original...Kerry. SDC Member #A012596W. ENCSDC member.
'40 Champion. sold 10/11.'63 Avanti R-1384. sold 12/10.
Studebaker used the Dana rears. Casting numbers on the housing would suffice. If any changes have been made, they would more than likely be significantly obvious.Brad Johnson,
'56 Sky Hawk in process
Originally posted by Buck View PostHow can I tell if it is still a Studebaker rearend? The car has been sitting in a garage for 10 years and I need brake parts.
I am pretty sure there were a few makes that had them, like Chrysler Products, but quite a ways back and may not have been in Dana 44's.
Jeeps would be a lot narrower.
Even the Ratios are peculiar to Studebaker: 3.07, 3.31, 3.54, 3.73, 3.92, 4.09, 4.27, 4.56 and 4.88Last edited by StudeRich; 09-08-2013, 10:36 PM.StudeRich
It it's a 44 (and no one has spuriously removed them), there will be a set of tags on the differential cover, like so:
As you can see (under all that grease and road grime!) there are 3 tags on a Twin-Traction rear end. One contains the Twin-Traction identification and lubrication instructions, another the ratio, and the last an ID number. If you have these, you've got a closed rear end.
Originally posted by SScopelli View PostA way to tell if it still has the TT, block the front wheels, ENGINE OFF, eBrake off and in Neutral..
Then jack up one rear wheel off the ground. If the tire spins, its not function properly, or its been removed.
Allen1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
Originally posted by studebaker-R2-4-me View PostAn easier way is to remove the plug and stick your finger in the hole, if it stops at the first digit you've got a twin trac.
