Does anyone have a transmission with overdrive they would like to sell? I would like to attach it to my 1950 or 1951 Champion engine. This is a car engine. Thanks!
Looking for Transmission
You need to let us know if you need it for a truck or car. I believe there is a difference in the application. Good luck finding one, they should be available, it just takes patience.John Clary
I have an OD trans in Phoenix from a 50 Champion. Don't have a lot of info on it due to the car had no engine when I got it, but I think all of the wiring, brackets and switches, etc are still in the car also. The bell housing is on it too, if needed, but would need to be indexed to your engine.
Make a decent offer and I can get it loaded on a Greyhound headed towards you.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
To put a T-96 3 Speed Overdrive Car Trans. in a Truck you still must have a SHORT Tail Trans. so 1958 and Newer one will not work, it must be From a '47 to '57 Champion.
You will also need a TRUCK Clutch housing to install it in a Truck. If it is not Factory fitted original to the Engine block, it will have to be "Dialed IN" to the centerline of the Crankshaft.
Of the Three Electrical components on the O.D. Trans. only the Solenoid cares about the Voltage, so you can swap it with a 6 Volt one if you find a '56 or 57 Trans. for 12 Volt.
You will need the Kickdown Switch, the Shift Cable, the Wire Harness and on some Older setups, also the Relay. Oh and probably a Shorter Front Driveshaft.Last edited by StudeRich; 08-25-2017, 10:10 PM.StudeRich
I was looking at a couple of three speed transmissions that I have and one has the rear mounting holes drilled and tapped on the bottom of the housing and the other just has the raised casting and not drilled and tapped, however could be re-machined to fit. I don't know anything about the history and what fits what. I did scrap a 53/54 truck some years ago and one of the transmissions may be from it.
Bill Heiker I have just been given a T86E -1 transmission. That is a truck transmission which will bolt up to the 1950 Champion car engine I have. I also inspected a 55 truck which also has a car Champion engine. The engine is a 1953. The 1955 truck has a T86E-1A transmission. The overdrive has R10 on the side. I don't know if R10 is the model number or what. I now know that I need at the very least, a compatible overdrive. If you have a T86E-1 transmission attached to an overdrive and know it is all in good working condition, I might be willing to take it. If not, I can make do with just the overdrive. I now know what I need so everyone can check to see if what I need is what you have. Please let me know. Thanks!
Mine is definitely NOT a truck transmission, so may not be what you need or want. Ratios might be better for driving then a truck trans, but might need some drive line modifications to work.sigpic1966 Daytona (The First One)
1950 Champion 4Dr
1957 Thunderbird
