Right way to apply 3M weather strip adhesive
  • Body / Glass: Right way to apply 3M weather strip adhesive
    I had to replace the trunk weather strip and decided I would try to find a good and less messy way to do it.
    I found this. Hopes it helps others out as it made my installation much easier. Notice the 63 Hawk plate also.
    Interesting, thanks for posting.
    Nick
      Don't to forget to clean the mold release , the white powder, off before gluing.
        Most of the rubber for our cars come with plenty of powder AND a very shiny rubber finish that does NOT want to accept adhesive. I speak directly to the little Lark pieces at the forward drain hole location. I've resorted to roughing up the shiny surface with a steel brush to create non-shiny, better sealing cavities for the adhesive. Clean before adhesive application with clean solvent...dry. Remember our old bicycle tube patch kits' with etcher ?
          The "wrong way" isn't necessarily wrong if you don't get the weather strip where you want it the first time. Some of us lack the hands of a surgeon.
            Looked too easy.
            So why do I see this after I have my car 80% done??? Oh well. At least the last 20% may go on easier and last longer than the first 3+ doors.
              I recently had a body shop guy tell me that they have begun using the double-stick molding tape on weatherstripping that is reasonably wide. Anyone tried that?
              Skip Lackie
