I bought a 50 Commander Starlite and am having a S10 front clip put on. What would be a good mate for a rear end that would support the same wheels and tire sizes It will sport a 350 and a 700r transmission. Thanks for your advice in advance.
rear end preference
Why not use the S-10 rear end also?Bez Auto Alchemy
Originally posted by mainmansam View PostI bought a 50 Commander Starlite and am having a S10 front clip put on. What would be a good mate for a rear end that would support the same wheels and tire sizes It will sport a 350 and a 700r transmission. Thanks for your advice in advance.
I agree with the thought of a complete S10 swap.
The end goal is to take a Stude that was never going to make it back on the road, and get it back on the road.
There have been quite a few successful S10 swaps done.
The S10 frame is easy to stretch or shorten (when compared to other frames).
And, if your donor S10 is nicely optioned, a lot of that can be retained.
As far as bolt patterns go... If you get a set of Wheel Vintique wheels, you can get multiple pattern stud holes.HTIH (Hope The Info Helps)
Have you read this thread? http://forum.studebakerdriversclub.c...g-II-front-endTrying to build a 48 Studebaker for the 21st century.
See more of my projects at stilettoman.info
My 52 Commander came to me with a 2002 Sonoma/S-10 rear end. It has a 3:42 gear and limited slip. The only issue is the different bolt pattern, but yours would match. It is a bit narrower than stock allowing a little more tire clearance."In the heart of Arkansas."
