I guess this would best be answered by Avanti experts who have worked on them for collision repairs. The only frame references I have, are the repair manual and the same diagram on Bob's site. Does there exist one with more detail, such as diagonal measurements, various heights at the front and back kick up areas, more detail on distances to the centerline at various points where the rails bend in and out? There appears to have been frame repairs on my 63 Avanti, and some things don't look "just right" especially on the front cross member lower, at the control arm bolt hole area and the left frame rail at the steering box. Looks to me that some pulls were made (evidenced by torn holes in the bottom plates) and some additional welding done to "put/push back" the bottom plate into contact with the rail where it separated, either during the impact or the pull. These welds are far from expertly done and before I bother to fix them, and start the bottom to top body repairs for refinishing, it would be nice to have something to use as a guide to see how far off everything is, make it right before I spend hundreds of hours restoring everything else. Anyone have one??
Better Avanti Frame dimensions-Anybody have??
Have you tried to find any crash sheets? I think that some of the frame pulling equipment manufacturers may have their own spec sheets, something to look for. Being authentic is one thing, but how about just replacing the frame? just a thought... Lou Cote
Originally posted by dynolou2 View PostHave you tried to find any crash sheets? I think that some of the frame pulling equipment manufacturers may have their own spec sheets, something to look for. Being authentic is one thing, but how about just replacing the frame? just a thought... Lou Cote
If this works right, I've attached the labor portion of the Mitchell Collision guide from the 1960's. BUT, it gives you a labor time to replace the frame, not frame specs.
Avanti (1963-1964).pdf (188.1 KB)
I might have more stuff if certain guides have info on Avanti II. Just heading to bed. I'll check the library tomorrow...Attached FilesTom - Bradenton, FL
Thanks Tom, although it doesn't show what I need, it is nice to have, better than the parts book, for me at least. I don't remember when the crash books started putting frame and later unibody diagrams and dimensions in them. Worked with Motors, Mitchell and later ADP-Audatex, computer based systems but can't remember which had them and when. I know most frame shops and body shops had a better reference to work with than what is in the repair manual. Maybe I need to check with companies like Chief or Blackhawk, they might have been proprietary at the time.
It took a bit of searching but I did find a copy of Motors Crash Book Service covering the Avanti , it has 4 pages showing frame a breakdown of all body panels,bumpers steering gear. I would be willing to make a copy of it for you,PM me with your mailing address. Lou Cote
Originally posted by dynolou2 View PostIt took a bit of searching but I did find a copy of Motors Crash Book Service covering the Avanti , it has 4 pages showing frame a breakdown of all body panels,bumpers steering gear. I would be willing to make a copy of it for you,PM me with your mailing address. Lou Cote
PM sent.
Fred
Originally posted by rkapteyn View PostBrand new frame rails are available from Nostalgic!
Originally posted by Bills R2 View PostBlack Hawk Automotive/Hein Werner has collision repair prints of Avant frames.
Fred, right now on Ebay there is a frame dimension sheet for '62-'65 Larks. These are the same as the Avanti and should work. It's all of $11.99.
Tom - Bradenton, FL
Originally posted by Swifster View PostFred, right now on Ebay there is a frame dimension sheet for '62-'65 Larks. These are the same as the Avanti and should work. It's all of $11.99.
http://www.ebay.com/itm/1962-1963-19...4AAOSwL7VWivbv
