After reading a lot about the difficulty of this job I decided to farm it out for my 61 Hawk. I talked to a couple of local glass companies and found an old independent shop that had some experience in installing glass in old cars that used the rubber gasket. He came out today to install the glass while I was at work. My Dad was there with them to oversee the process. Nothing got broken, but nothing was installed either. They spent about 4 hours working on the front glass and finally gave up. They never even touched the rear glass. The report was that it went in fine across the bottom and up the sides but would not go in across the top. The assumption is the headliner is adding too much thickness to the body lip that the rubber is supposed to fit over.
I wrapped my new headliner over the lip and it is glued on both sides of that lip. I wrapped it because that is how the original headliner was installed when I pulled the glass out of the car. I have new rubber gaskets from SI and a new headliner from Rene Harger. I am re-using the original windshield.
I know modern vinyl is thicker than that paper thin stuff they used back in the day. I have also heard that new glass is not as thick as the original glass.
Any suggestions? If I cut the headliner off of the outside of the body lip, will the lip on the rubber gasket roll the headliner down the inside of the body lip when it goes in? Is there any truth about modern glass being thinner than the original galss? If new glass is thinner and I bought new glass would the thinner glass help with this install problem?
Thanks
Wayne
Thanks
Wayne
