All12 volt generators are not equal. The regulator has to match the current output of the generator as well as how the field voltage is controlled. Most Autolite Generators supply voltage to the generators field terminal and most Delco generators ground the field terminal. In both cases by the voltage regulator to control the generators output.
Use the wrong regulator and the generator might not charge or possibly overcharge the battery. It is also possible to burn out the generator and or the regulator.
The 12 volt regulators have a battery terminal, a field terminal and a armature terminal and some have a 4th ground terminal. The 1957 Studebaker Service manual has a good right up on the various charging systems used. It is unfortunate that most old time electrical service shops no longer exist. They had the books that matched up the generator to the proper regulator. The shop that I worked in as a teenager no longer exists. The owner is retired living in PA.
Ron
Ron
