Anyone have one of these they'd part with ?
  • Body / Glass: Anyone have one of these they'd part with ?
    The fender vent operating mechanism....
    (because the air conditioner hardware gets in the way of the normal operating mechanism on the passenger side, and this seems like it would work if I modified the little door.)
    '53 Commander
    Art Morrison chassis
    LS6 ASA/4L60E
    I had that same issue. What I did was cut the rod from lever to door match the bend that moved the lever under the glove box and out of the way of the under dash a/c.
      I have had the same issue with all Hawks I've installed AC on. I simply bend the little, round handle end about 90 degrees, to where it is pointing straight toward the passenger side of the car. It will then glide along, just above the AC evaporator. You'll need to use the fingertips a bit more, but it works slick as a whistle.
        My a/c unit is a little too close for that, I've been goofing around with it for a while, and it really looks like the best solution is to mirror the other side. I have a little door for that, too.
        '53 Commander
        LS6 ASA/4L60E
          I think I may have a spare. I'll check tomorrow
            I'm installing A/C in my '64 GT and have been looking at that issue as well. It seems that Stude moved the mounting bracket to the right -about the distance of the screws that hold it under the dash. The rod is then shortened that length accordingly.
            Rob in PA.
              [ATTACH=CONFIG]45718[/ATTACH]
              I found one, but it will have to be plated or painted. I don't think it will clean up. I have the lever and rod. didn't see the little plate. If you don't find a nice one, let me know. I will look for the little plate the weekend. Course if you don't want it I won't hunt the little plate
                If you want to get fancy you could use this,
                Results: Dashboard»Cowl Vent @ Street Rod Headquarters is the World's Most Complete Supplier of 1937-1954 Chevrolet Classic Restoration Parts and Street Rod Parts for your Car and Truck.
                Bill Foy
                1000 Islands, Ontario
                1953 Starlight Coupe
                  Would love to have it. Let me know the details ($, postage etc.) and I'll get that to you. The little plate would be a bonus, have to make one otherwise.
                  '53 Commander
                  LS6 ASA/4L60E
                    I will do. Check for the 4 bolt plate and get it ready to mail. Let you know.
                      PM me your mailing address.
                        Posted yesterday and lost in space I guess?? ralt12 your lever is on the way.
                          Checking from across the country, on the road, thanks so much for the help, hopefully I can return the favor !
                          '53 Commander
                          LS6 ASA/4L60E
