Vaporlock was addressed in a 1958 S-P tech bulletin, for supercharged cars, and I suspect it also applied to other Studes. One suggestion in the TB was to run straight water in summer, because it cools the motor a few degrees better.
I once saw a video of a "desert Studebaker" from the early 50s, destined for the Middle-East. It had a radiator that looked to be about 4" thick.
Your Hawk, at 100-110 outside temps, will continue to overheat if idled more than a few minutes, i.e. in a McDonalds' drive thru window line, long red-lights, etc. Unless, you run a modern 3-row radiator (equal to about 4-5 row from the 1960s, if they'd made such a thing), and a 16" pusher fan in front. Wire the fan so you can turn it off/on from inside, and flip it on anytime you anticipate idling more than a minute, in 100-110 degree weather. If you have AC, turn it off at those times.
This worked for me, while living in the California desert for 6 years, driving nothing but Stude Hawks, which all had AC. On the road, they will usually run around 195-210 in summer too, but that is not a problem. If it hits around 225 or up, it will start to vapor lock even while idling and/or moving slowly. But with a good radiator, it should seldom, if ever get that hot.
