Today was one of those days when you don't get much done because of other things that have to be done
But I managed to get the front seat in the car to locate the center seat belt anchor points (trans tunnel area). I made these anchor plates out of the two extra plates I had bought for the overhead. I bought two extra in case I messed one up during the modification process. Anyway, I welded the anchor plates to a larger plate to make sure it pulled the forces over a large area:
I put a slight curve on the plates to better match the inside of the trans tunnel:
Then I made some extensions to have something to attach the inner seat belt latch to. Since I raised the seat for my daughter there's no way the factory seat belt latch assembly would reach the floor.
The front seat is in the correct location (and height), I had my daughter sit in the car (one more time) to get a good bead on where the seat belt latches needed to be. Now I'll just pop a couple of holes ( being careful around the driveshaft) in the tunnel and install the extensions. I also called ISI instruments to check the status of the fuel gauge and the sender. They said it would ship out TODAY!!!!
Which means that next week I should be driving the car again and start the "shake down" process. There are very few items left on the Studebaker "to do" list. Some minor wire hook up to the new fuse box, a fusible link, install the fuel gauge, trans cooler, etc. I'll replace the rear end later on after my daughter has driven the car for a while.
Treblig
Treblig
