Can someone tell me where to find the carburetor identification number on a WCFB carburetor. I have a list of all of the WCFB carbs ever used on any model of Studebaker car or truck. I am considering buying a WCFB from a seller who doesn't know where this number is located and I don't know where to tell him to look. (The tag is missing and I think all other numbers on the carb are casting numbers for the individual components. He thinks it is a Studebaker WCFB but I want to be sure.) Thanks.
WCFB Identification
On the front of the Right Front (Passenger side) leg of the Mounting Base, stamped into the edge.
The '55 to '58 and the '59 to '64 Studebaker Chassis Parts catalog lists the Carter WCFB model numbers used each year up to '62.
The Studebaker Versions have the Fuel Inlet on the Right front corner, facing Forward.StudeRich
I believe StudeRich is thinking of where to find the I.D. on a Carter AFB carburetor. On the Carter WCFB carbs, there is no stamped I.D. number on the base. If the brass tag is lost, then there really is no way to identify exactly which WCFB you have. (The side lever arms that attach to the throttle linkage vary from make to make...The Studebaker setup being somewhat unique) Fortunately, the available WCFB rebuild kits are all the same, as the WCFB carbs themselves were pretty much all the same.
Thanks for the additional information. I have forwarded all remarks to the seller and have asked him to send me a close-up photo of the throttle linkage side of the carburetor. If I get this photo from him, I will try to post it here and then maybe someone will at least be able to confirm that it is a Studebaker WCFB (or not a model used by Studebaker).
Originally posted by studebacher View PostI just saw this "tip" on "The Carburetor Shop LLC" website concerning the identification number on a WCFB carburetor. I copied the script and and here it is: W Series (WCFB)
If linkage connections are what distinguishes Stude WCFBs, perhaps the seller can provide a pic, for you to compare with a pic in the Stude Shop Manual.
Yes, the Carter WCFB's were all very similar in appearance. (excepting for the side linkage) However, the earliest models do look a bit different, as the cast iron base plate was much smaller. Those early models were designed to fit narrow intake manifolds, such as a straight eight Packard. But even on those early models, the center section and upper air horn were pretty much the same as on the WCFB's that came later.
Not all of them had the brass balance tube for venting like later models, also some had vents on the metering rod adjustment cap, and some had secondary air valves and an external counterweight.Bez Auto Alchemy
I now have pictures of the throttle linkage side of the WCFB. I know it is out of the question to determine what model number this carb is (with the brass tag missing) but as long as it is a Studebaker WCFB, it would serve my purposes. Please have a look and tell me if this is a Studebaker WCFB or not.
