For ALL that are or will be using Harland Sharp roller rocker arms with the OEM style cam/lifter -
Here's what I've found:
1. Studebaker uses 3/8" dia. ball on both ends of their pushrods.
Harland Sharp furnishes 5/16" cup adjusters when you buy their rockers.
BAD for oiling..! Very little bearing surface.
2. T&D Rocker Arms seems to be the only place in town (many calls all over..!) that has 3/8" cup adjusters.
They are $10.00 each. Plus they may not be long enough. I have "one" in the mail now to see if they will work properly.
3. Smith Brothers will furnish thin wall 3/8" dia pushrods (like Stude only better material) with 3/8" ball on one end and 5/16" ball on the other end.
They are $9.00 each.
Actually most pushrod builders will do this, but at $9.00 ea, I felt in not nesessary to continue my search. I'll get them out a sample pushrod hopefully tomorrow.
P.s. - T&D can also build basically one of the best, most accurate rocker arm assemblies in the industry, but to do this for the Stude engine AND make it somewhat affordable to us, they'll need to build 20 sets (sound familliar ?).
And for what it may be worth, they use roller bearings rather than bushings like most. Their shafts are designed for this.
Any thought's out there..?
