More on Oil Filters
  • Engine: More on Oil Filters
    I decided to start a new thread since I learned something from the previous thread I started, from Jeff, Randy, Rich, and others. There are lots of interchanges for oil filters, but they have to have the same, but very close gasket sizes, and close diameters, (and height may be a factor, if it is a spin-on conversion to one of the C or K models), or others. I originally asked about spin-on conversions for the 283 McKinnon V-8, which Rich supplied as the WIX 51069, which also crosses to the Fram PH30, and the tall (8") PH373, as recommended by Jeff. Then there was my photo of the quite short PZ-18A mounted on my Sky Hawk 289, which crosses with both the WIX 51372 and the Fram PH2. As well as the Fram PH50, and I'm sure they're others. Photos to follow.->->->->->-> Note the adapter, Fram 108089, which allows me to use a a spin-on filter on the Sky Hawk, which came with the "cartridge in the can" partial flow filter. This may be as good as the stock cartridge filter, or at least it's better than no filter.
ID:	1744445Click image for larger version
ID:	1744446Click image for larger version
ID:	1744447Click image for larger version
ID:	1744448Click image for larger version
ID:	1744449Click image for larger version
Name:	WIX 51050.jpg
    Regarding the McKinnon 283 in my 65 Cruiser, there are several adaptors available on-line, and they will let you spin-on (screwon) the filters mentioned by Rich and Jeff. This probably has a "Fram HPK1 adapter or a Mr Gasket 1270 adapter, which converts a bolt-on, can-type filter to a full-flow, spin-on filter. The one-piece construction allows easy installation for a fast, clean filter change. A rubber O-ring is included. Must use with original bypass valve. Filter is not included; use a Wix 51069, Fram PH-13, AC PF-25 or equivalent. Fits Chevrolet 1957 thru 67 small block and 1965 thru 67 big blocks." Or it could be the Fram K98ADP as mentioned by Jeff, which would take either of these filters as "full flow", or for extra cooling, the Fram PH373, which holds an extra quart of oil. A question for Rich: What makes a spin-on filter a "partial flow filter" instead of a "full flow filter"? Isn't just the mounting and how the oil is directed through the filter?
Name:	Fram K98ADP.jpg
ID:	1744454Click image for larger version
Name:	Fram PH373.jpg
ID:	1744455Click image for larger version
Name:	WIX 51069.jpg
    Jack, in Montana
    Confused my your thread title. I thought this would be about dumb oil filters.
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
      Right, Ed. I think it is supposed to be: More On Oil Filters! BP
        MoronSpinon Oil Filters
        Right, I made a mistake in the title. It should have been Moron-Spinon Oil Filters
        Now edited with photos.
        Jack, in Montana
          I don't think you should have mixed up Partial Flow Filters like a Fram PB50 and it's equivalent Filters with the Totally DIFFERENT Types of Spin-on Filters for Full Flow Engines like WIX 51069 completely different Animals for a different Location, Engine and purpose.
          I don't see the noted custom aftermarket Adapter I was expecting for the GM Engine adapter to convert from the Full Flow Canister to spin-on conversion.
          All I see is the Studebaker "Upside Down" Filter Mount used on all '58 to early 1960 Stude. V8's which are ALL Partial Flow.
          Also a bunch of unknown Filters and Gaskets that should not be removed from Filters.
          Do I misunderstand something, or are you REALLY cornfused?
          The PZ-18A is NOT a Studebaker Filter, and I do NOT believe it is for a Partial Flow Engine.
          If you find the thread size incorrect, that is to PREVENT someone from using a Full Flow Filter (unrestricted) on a Partial Flow restricted Filter application/Engine.
          I will refer this to Jeff, the Oil Filter Pro for clarification.
            Rich are you forgetting the PB-50 was used on1957 supercharged cars also? (behind the pressure bonnet).
            Bez Auto Alchemy
              Just for Clarity....
              The spin on filter specs for the PB50 bypass spin on filter are:
              Part Number Part Type Supplier Buyers Guide
              PB50 Engine Oil Filter Luber Finer Fiat, Kaiser Jeep (1965-68), Rambler (1958-64), Studebaker (1957-62)
              Parts Catalog
              Part Number: PB50
              Print
              Spec. Value
              Description OIL
              Packaged: 1 Gasket
              Anti-Drain: None
              PSI Relief: None
              I.D.: 5/8"-18 Thd.
              Height: 5.12 [130mm]
              O.D.: 3.81 [97mm]
              Buyers Guide Application Fiat, Kaiser Jeep (1965-68), Rambler (1958-64), Studebaker (1957-62)
              And the replacement mounting head assembly for the PB50 filter is a Luber-finer p/n# LMB50
              This is the Luber-finer replacement for the Fram 108089, which does not appear in the current Fram price sheet.
              The specs for the LMB50 are:
              Parts Catalog
              Part Number: LMB50
              Print
              Spec. Value
              Outlet: 1/8"-27 NPTF
              Buyers Guide Application Mounting Base used w/PB50 B/P filter
              Description BASE
              Threaded Stud: 5/8"-18 Thd.
              Inlet: 1/8"-27 NPTF
              Here are the specs for the Fram PB50:
              Part Number PB50
              Zoom
              Product Type By-Pass Lube Spin-on
              Anti-Drain Valve NO
              Gasket I.D. 2.42"
              Gasket O.D. 2.8"
              Gasket Thickness .2"
              Gasket Usage Base
              Product Height 5.13"
              Product I.D. 5/8-18 Th'd
              Product O.D. 3.78"
              Need help installing this product?
              Applications Where Used
              ALLIS-CHALMERS
              ALLIS-CHALMERS (Diesel)
              ALLIS-CHALMERS-LIFT TRUCKS
              ALLIS-CHALMERS-PUMPS
              ALLIS-CHALMERS-TRACTORS
              AMERICAN MOTORS
              B&W LATHROP (Marine)
              BAKER INDUSTRIAL
              BAKER INDUSTRIAL-LIFT TRUCKS
              BELARUS
              BELARUS-TRACTORS
              CATERPILLAR
              CATERPILLAR-LIFT TRUCKS
              CHAIN BELT
              CHAIN BELT-CONSTRUCTION EQUIPMENT
              CHECKER
              CHEVROLET
              CHICAGO PNEUMATIC
              CHICAGO PNEUMATIC-AIR COMPRESSORS
              CLARK
              CLARK-LIFT TRUCKS
              CONTINENTAL TELEDYNE
              EXCEL
              FIAT
              G.H. TENNANT
              G.H. TENNANT-SWEEPERS
              GMC MEDIUM DUTY TRUCK
              HARDIE
              HARDIE-SPRAYERS
              HERCULES (Gasoline)
              HINO TRUCKS
              HOLMAN
              HOLMAN-AIR COMPRESSORS
              HUBER-WARCO
              HUBER-WARCO-GRADERS
              HYSTER
              HYSTER-CRANES
              HYSTER-LIFT TRUCKS
              ISUZU
              JEEP TRUCK
              JOHN DEERE
              JOHN DEERE-SKID STEER LOADERS
              KAISER-JEEP
              KAISER-JEEP-POWER UNIT
              KOEHRING
              KOEHRING-SKID STEER LOADERS
              LULL
              LULL-CONST. EQUIP. OR FARM EQUIP.
              MASSEY-FERGUSON
              MASSEY-FERGUSON-TRACTORS
              MILLER ELECTRIC
              MILLER ELECTRIC-ARC WELDERS
              OLIVER
              OLIVER-TRACTORS
              PACKARD
              PCM
              PCM-EARTHBORING MACHINES
              REX
              REX-ROAD BUILDING MACHINERY
              STUDEBAKER
              STUDEBAKER TRUCK
              TOWMOTOR
              TOWMOTOR-LIFT TRUCKS
              WAUKESHA
              Competitor Cross Reference
              AC-DELCO P3
              ALLIS-CHALMERS 1EK11972
              ALLIS-CHALMERS 4512207
              ALLIS-CHALMERS 45122074
              ALLIS-CHALMERS 4512207-4
              ALLIS-CHALMERS 74900600
              ALLOY ABH-50
              AUTOPAR FE20
              AUTOPAR FE63
              B&W-LATHROP P-2417
              BAKER 101254
              BAKER 737R1
              BAKER 737W1
              BAKER 9033AM1
              BALDWIN B222
              BALDWIN B296
              BALDWIN B494
              BALDWIN B50
              BIG A 92050
              BOSCH 0451202001 1
              CANADIAN TIRE 17-1722
              CARQUEST 85050
              CATERPILLAR 3I-1113
              CATERPILLAR 6663172
              CATERPILLAR 68147
              CATERPILLAR C-68147
              CENEX CO97
              CHAMP PB50
              CHAMP PH226
              CHAMPION OF412
              CHECKER 95021
              CHRYSLER 2196908
              CHRYSLER 3154364
              CHRYSLER 8990508
              CHRYSLER 925418
              CHRYSLER 928055
              CHRYSLER 936407
              CHRYSLER 991718
              CHRYSLER J0925418
              CHRYSLER J0928055
              CHRYSLER J0936407
              CHRYSLER J0991718
              CHRYSLER J3154364
              CHRYSLER J8990508
              CLARK 1752522
              CLARK 990936
              CO-OP PL-50
              COOPERS AZL057
              CROSLAND 536
              DELUXE WD-97
              DONALDSON LFP550050
              DONALDSON P550050
              DONALDSON P550196
              DONALDSON P550972
              DONALDSON P559615
              DYNALIFE CN-51050
              DYNALIFE CN-7
              FACET 50
              FIAAM FT4418
              FIAT 4007348
              FIAT 4026075
              FIAT 4083490
              FIAT 4107775
              FIAT-ALLIS 74512207
              FILTERS INCORPORATED OF50
              FLEETGUARD LF3543
              FLEETGUARD LF607
              FLEETGUARD LF786
              FLEETRITE LFR-8607
              GENERAL MOTORS 5574639
              GENERAL MOTORS 5574641
              GENERAL MOTORS 94169779
              GENERAL MOTORS 94360419
              GONHER GP50
              GONHER GP50M
              GRAND PRIX PB50
              GROUP 7 L30003
              HASTINGS LF117
              HASTINGS LF198
              HASTINGS LF445
              HERCULES 208728
              HERCULES 256274
              HERCULES 256274-B
              HERCULES 286760-C
              HOBART 509021
              HUTCHEN S-3
              HYSTER 180282
              HYSTER 180320
              HYSTER 181769
              HYSTER 3000043
              ISUZU 8-94169-779-2
              ISUZU 8-94360-419-0
              ISUZU 8-94360-419-1
              ITM 11-16305
              JIFFY LUBE HL50
              JOHN DEERE HMF600L04340
              KNECHT FO-356
              KNECHT FO-370
              KRALINATOR L23B
              KRALINATOR L30
              LEE LF-3
              LPM 1350-5050
              LUBER-FINER LFP2270
              LUBER-FINER LFP3
              LUBER-FINER PB50
              LUCAS GIRLING F5541
              LUCAS GIRLING F646
              MANN & HUMMEL WP9.31/1O
              MANN & HUMMEL WP931
              MARATHON PB50
              MARATHON-LETOURNEAU PB50
              MASSEY-FERGUSON 1032015-M91
              MASSEY-FERGUSON 1900377-M91
              MASTER PARTS PB-50
              MIGHTY L20024
              MIGHTY L30003
              MIGHTY PB50
              MITSUBISHI J0925418
              MITSUBISHI J0928055
              MITSUBISHI J0936407
              MITSUBISHI J0991718
              MITSUBISHI J3154364
              MITSUBISHI J8990508
              MOBIL L30003
              MOPAR L-4
              MOTORCRAFT FL 3
              NAPA 1050
              NELSON 85006-A
              NELSON B-335-SCR
              PHILLIPS 66 P3
              PHILLIPS 66 WO1050
              PROMATCH 68147
              PUROLATOR L10019
              PUROLATOR L30003
              PUROLATOR L35492
              QUAKER STATE L30003
              QUAKER STATE PO-116
              ROL-PAK FPB-50-BP
              ROL-PAK FPBQ-50-BP
              RYDER 990936
              SHELL L30003
              STP PB50
              TELEDYNE F-600L-4340
              TENNANT 53055-2
              UNITED (ENGINE LIFE) U4L
              UNOCAL OF1050
              WALMI WS-50
              WARNER PB50
              WAUKESHA 199269
              WGB S-87-CP
              WHITE 104397-A
              WHITE 1-4397-A
              WHITE 600136-AA
              WHITE 60514-AS
              WHITE 605814-ASA
              WIX 51050
              Originally posted by jnfweber View Post
              I decided to start a new thread since I learned something from the previous thread I started, from Jeff, Randy, Rich, and others. There are lots of interchanges for oil filters, but they have to have the same, but very close gasket sizes, and close diameters, (and height may be a factor, if it is a spin-on conversion to one of the C or K models), or others. I originally asked about spin-on conversions for the 283 McKinnon V-8, which Rich supplied as the WIX 51069, which also crosses to the Fram PH30, and the tall (8") PH373, as recommended by Jeff. Then there was my photo of the quite short PZ-18A mounted on my Sky Hawk, which crosses with both the WIX 51372 and the Fram PH2. As well as the Fram PH50, and I'm sure they're others. Photos to follow.->->->->->-> Note the adapter, Fram 108089, which adds a spin-on (spinon) partial flow filter.
              [ATTACH=CONFIG]36867[/ATTACH][ATTACH=CONFIG]36868[/ATTACH][ATTACH=CONFIG]36869[/ATTACH][ATTACH=CONFIG]36870[/ATTACH][ATTACH=CONFIG]36872[/ATTACH][ATTACH=CONFIG]36871[/ATTACH]
              Regarding the McKinnon 283, there are several adaptors available on-line, and they will let you spin-on (screwon) the filters mentioned by Rich and Jeff.
                Good points, Rich.
                As stated in my original reply on the original thread...
                But...
                I am checking on this adapter to see if it has the built in bypass valve(s)
                The pic is not clear about that.
                More later...
                (copy)
                Here you go.....
                Get a Fram p/n# K98ADP (filter adapter kit) to upgrade from a cannister oil filter on a McKinnon V8 to convert to a spin on oil filter.
                  Rich, not realy cornfused? I was discussing two different applications for two different cars, one a full-flow 283, and one a partial flow 289. See the modifications I made to my original "moronic" post.
                  Jack, in Montana
                    Well, maybe I've learned something!
                    I decided to reply to myself by correcting my initial entry since I learned something from Jeff, Randy, Rich, and others. There are lots of interchanges for oil filters, but they have to have the same, but very close gasket sizes, and close diameters, (and height may be a factor, if it is a spin-on conversion to one of the C or K models), or others. I originally asked about spin-on conversions for the 283 McKinnon V-8, which Rich supplied as the WIX 51069, which also crosses to the Fram PH30, and the tall (8") PH373, as recommended by Jeff. Then there was my photo of the quite short PZ-18A mounted on my Sky Hawk 289, which crosses with both the WIX 51372 and the Fram PH2. These fit and spin on and do not leak, but they may not function as filters, since they were designed as full flow. The Fram PH50 is a full flow filter, and is correct with my adaptor, Fram 108089, which is NLA as Jeff points out. The adapter allowed me to mount a spin-on filter with the correct thread and gasket sizes, but it may not work as an effective filter, or not at all. At least it collects oil.
Name:	WIX 51050.jpg
Name:	WIX 51069.jpg
                    Jack, in Montana
                      <snip>What makes a spin-on filter a "partial flow filter" instead of a "full flow filter"?
                      Here's your answer....
                      "Partial Flow" is the term used for the oil distribution system on early (pre 1962) cars.
                      The oil comes out of the pump and goes immediately to the cam/main/rod bearings.
                      Nothing is filtered right out of the pump.
                      An 'add on' filter was installed and a line tapped off of an oil pressure port (a head in the case of the Stude) and that oil gets filtered and drained back into the oil pan.
                      But only part of the oil gets filtered. Hence the name 'partial flow'.
                      A 'full flow' oiling system is one where ALL of the oil coming out of the oil pump gets filtered BEFORE it goes to the cam/crank/rod bearings.
                      Studebaker made an adaptation to change the partial flow filtering system they used from 1952 to 1962 to a 'full flow' system for late 1962 through 1964.
                      The filters used in a partial flow system have different requirements than a full flow system.
                      Most partial flow filters that mount the filters up high and upside down usually have an anti drainback valve (which has a very low psi rating) just to make an oil change a lot less sloppy.
                      And most partial flow filters do not have a 'bypass valve'. If the filter gets clogged, the filter just stops flowing.
                      They ran the filter through a restrictor fitting anyways, just to keep the system oil pressure up.
                      There would be no immediate catastrophic engine failure if a partial flow oiling system stopped functioning.
                      All 'full flow' oiling system filters usually must have an internal bypass valve to allow pressure spikes and over pressure to be bled off (clogged element is one example) before the housing could rupture or the element tear or collapse.
                      Most engines built that bypass valve into the filter housing adapter....but not all.
                      Studebaker's full flow system has the bypass valves built into their 'bolt on' housing on the lower side of the block.
                      The bypass valve on the filter itself opens under high pressure (clogged element) and the oil just goes right through the filter can without being filtered, to keep oil pressure going to the cam/crank/rod bearings.
                      Does that clear it up?
                        Thanks Jeff, I could not have said it that well.
                        I think the simple bottom line may be that the "Spin-On" Partial Flow Filter used for convenience on '57 GH's and '58 to early '62 Studes., should not be confused with a Spin-On FULL FLOW type Oil Filter usually on the Bottom of an Engine, they are Night and Day different internally and MUST only be used on their designed for Engine setups.
                        To me it is simple, just buy ONLY the Studebaker specified type Filter, direct crossover to various different Brand name Part Numbers.
                          Yes, thanks, Jeff. I made some corrections on my latest and initial post and think I've got it right. You are right, the PZ-18 which fit and did not leak, was a bit "sloppy" to remove.I put a few "Brawny" paper towels under it. Filter changes are nonetheless sloppy, even with "check valves". I am on my way to AutoZone in Butte tomorrow to pck up a couple of PH11's for my Avanti and 64 Cruiser, a PB50 for my Sky Hawk, and a PH30 for the Chebbybaker. I have been running my M-5 and '48 Champion for years without filters and doubt if I have caused much damage considering how little they're driven. For that matter, most of my Montana cars have not been driven much further than out to the Interstate and back (12 miles) every few months for the past 8 years.
                          Jack, in Montana
                            That is considered extreme use in engine circles.
                            Short run times tends to put a lot of condensation/moisture into the oil, and that moisture can accumulate, turn acidic, and rest on the bearings and corrode the bearings and crank/cam/rods.
                            If you have very short run times, you should change your oil more often.
                            Nothing wrong with not having a filter. Filters came years...decades..after the engine came along.
                            Just change your oil more often.
                            If you do run your engines occasionally, run them at least an hour to fully heat up the engine....and the exhaust system.
                            Get everything good and hot...and dried out.
                            Your exhaust system will last a lot longer, and your engine will thank you.
                            <snip>
                              One nice thing about most of Montana, it's cold and dry. I always run the cars up to thermostat temperature, and above that, in summer. Rust is not much of a problem even if the car sits out in the weather on the prairie, since humidity is low and there is often not much condensation at night. That is why it is easy to find many almost rust-free cars with good chrome around here.
                              Jack, in Montana
