On another thread a lot of people were disparaging the GM 305 engine that I have.
I feel that if you are going to run it in stock condition on the street, it's a pretty good lump -especially for the price (everyone has heard that a 350 is better, right? - so the price of a lowly 305 is lowly as well!)
I stole this from the Camaro forum. It basically says what I said, but gives details why:
ifmodded TPI set up is the way to go ect, it's primarily because most of the time people are talking about using them on the 350s. For the 305 the stock TPI intake is pretty decent. This is why the hp ratings for the 350 and the 305 are so much closer than one would expect - it's just a better match for the 305 in its stock form. When they were designing the TPI intake their designs was based off of the 305's air flow data as rumor was GM was uncertain about the 350s future due to the emissions regulations. Because of this, it has been noted that swapping on larger runners onto a 305's TPI system yields marginal gains on the dyno. The biggest short falling of the LB9s were its camshafts. The 2 cams offered for the LB9 were terrible one even earning the nickname the "peanut cam." The sad thing is even using the slightly less crappy cam offered an additional 25 hp over the "peanut cam." With a good cam and full exhaust system (headers, high flow cat, with a performance cat back of your choice) it would not be unreasonable to expect around 270 hp with nearly 400 ftlbs of torque out of an otherwise stock LB9"
