Hi, I recently finished removing all pistons finally. I now have to remove the camshaft. The engine is a six cylinder 170. What is the easiest way to remove this camshaft as well as the oil pump gear that is fitted to the camshaft.
Removing Camshaft
Originally posted by greatbarnfind View PostHi, I recently finished removing all pistons finally. I now have to remove the camshaft. The engine is a six cylinder 170. What is the easiest way to remove this camshaft as well as the oil pump gear that is fitted to the camshaft.
Keep your Valve Lifters in ORDER, in case they will be going back in without a Cam Re-Grind or Lifter re-surfacing.
It is best to drill 12 holes 3/4's of the way through a piece of 2 X 4 marked "Front" on the end and keep them stored in a dry place lightly Oiled.StudeRich
