1947 Champion Defroster
  • Cool/Heat: 1947 Champion Defroster
    I was working on the 47 last night and managed to get the heads off the two bolts left holding the heater control valve and switches up. I then took the radio out. I see the defroster duct is quite rusty and the spigot for the hose is rusted away. Would anyone know if the defroster duct/plate that the 47 champions use is bolted or welded in place? If bolted, i will try to get a new one made or a better used one - especially for the right hand side.
    I would appreciate nay help on this. Upside of getting the radio out is now I can get in there and fix the crossed windshield wiper cables to get the right hand wiper going the right way.
    Neil
    I can't speak specifically for a 47 but the duct on my 54 is attached to the blower motor with a sheet metal screw. Dave British Columbia
      On the 47 there is a screw holding on the metal Y for the duct work. If that is rusty I would suggest you pull the defroster assembly and check for rust in the blower cage. The defroster assembly is the same for all 47-55 cars in case you need to replace the complete assembly. The squirrel cage on the blower is not easy to remove if it is rusted. Good luck
      Milt
      1961 Hawk 4-speed
      1967 Avanti
      1961 Lark 2 door
      1988 Avanti Convertible
      Member of SDC since 1973
        Hi Milt. Mine is like the attached picture with no Y. I think the Y started with the 1949 cars per the parts book. The spigot the hose mounts to is rusted away. I was wondering if the piece the spigot mounts too is part of the body weldement or a bolt on part on the 47. Looks like it is part of the weldment as I can't find it in the parts book anywhere.
        Neil
          You learn something everyday. I have a 47 Champ and never have really looked at it under the dash. From under the hood it looks like the later years and I assumed it was the same.
          Milt
          1961 Hawk 4-speed
          1967 Avanti
          1961 Lark 2 door
