Subject: antifreeze ... Do Not Use in cars over 10 years old
Cool/Heat: Subject: antifreeze ... Do Not Use in cars over 10 years old
Curt Devan
Kirksville, MO
Editor, Mid Missouri Chapter Newsletter "Studie News"
sigpicTags: None
Yes, Curt, that information is somewhat dated and should be updated, but not totally inaccurate: OAT-formulations were shown to possibly cause some galvanic action between dissimilar metals when cars were left in storage unused for many months. You wouldn't notice it in a daily-driver.
Common, green, basic, old-formula ethylene-glycol antifreeze is still readily available in most markets, often priced less than newer formulas, so why not use it?
You're sure to find it at places like Tractor Supply, Farm & Fleet, Big Blue Stores, and such. It is usually private-label. (I hope it doesn't deteriorate too fast; I bought six, 6-gallon cases of it at Menard's a couple years ago and still have four cases left! Personally, it's all I use, with a bottle of anti-rust added every other year, in my own collector cars.)BP
Originally posted by jnormanh View PostTotal baloney. My 17 year old Caddy came with extended life AF from the factory. I changed it at 100k and will change again at 200k. No problems whatsoever.
Originally posted by oldsalt View PostMy cad also came with the extended life crap. So I used it in a nice 70 Chevelle LS-6 believing that "nothing is too good" for a collector car.. Bad, bad mistake. Don't know if "10 years" is the absolute and 100% cut-off date, but I do know that if a guy is in doubt DON'T put that red garbage in your system. What is there to gain by using it if there is ANY doubt because it is a tried and tested and true fact that t will be injurious to early systems.--------------------------------------
Originally posted by 1962larksedan View PostWe used to call that red coolant which GM started using ca. 1996 'Deathcool' vs. 'Dexcool'.BP
Originally posted by BobPalma View Post(I hope it doesn't deteriorate too fast; I bought six, 6-gallon cases of it at Menard's a couple years ago and still have four cases left! Personally, it's all I use, with a bottle of anti-rust added every other year, in my own collector cars.)BP
Don't go by color. I know for a fact that Toyota uses an anti freeze that is red in color but if you look at the container it is ethylene-glycol. When GM started using Dexcool I remember that it was being recommended in all their cars except Saturn. Perhaps because Saturn at the time was the only one using aluminum heads on iron blocks & the coolant would have had an effect on the galvanic reaction between the dissimilar metals.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
I have started several replies to this, but hesitate to post info on this because it is an area that is in a state of change.
The buzz word in coolant is 'Extended Life'.
This means different things, in different industries, for different reasons.
The 'new' truck industry (diesel engine) has changed from a SCA additive coolant (which is still available) to a different chemical mix on 'extended life' coolants.
The newer 'extended life' coolants have a different chemical package than the older SCA additive package.
SCA in coolant is used to prevent cylinder liner pitting in diesel engines (and it helps solve cavitation problems in gas engines as well).
If one reads between the lines on the article, and one were to use the later HD diesel 'extended life' coolant, there might be an issue.
But.....
The automotive industry (truck and pascar) is changing.
And this change is OEM driven. Particularly engine builder driven.
Coolant chemicals and blends ARE changing, and they are changing for current vehicles.
The older pascar market is still being served by the various coolant manufacturers, and existing coolants will do the job as demanded.
And don't go by 'color'.
There have been so many coolant manufacturers adding 'color' to coolants that have no meaning from brand to brand.
There is no industry standard (SAE) about coolant color that I know of.
My coolant of choice for Studebaker's (any and all) is:
Prestone HD "Purple" p/n AF957 (50-50 Pre-Mix)
AF957 Prestone HD Pre-Charge 50/50 Gallon Purple
It has the SCA additive package already in it (which might be overkill for a gas Stude engine, but it won't hurt it).
The water used in the 50-50 Pre-Mix is deionized filtered water, which is better than 99% of all tap water out there.
My second choice would be the Prestone All Makes 50-50 coolant.
The purple has more additives in it that will help to protect the metal in the engine and radiator.
AF2100 Prestone All Makes All Models 50/50 Gallon Yellow
So, the consumer choices are great, and some of these choices are not compatible with older cars and light duty trucks (gas powered).
Be a smart shopper, and buy what the coolant manufacturer recommends.
No... The sky is not falling.
Forums and blogs get a ton of info posted that is not always correct, or complete.
And posters need to be careful in posting about what worked in 1963 will work in 2013.
Maybe it will... Maybe it won't.
If someone has questions about coolant, you can contact me off the forum and I will answer any of your questions, or find the answers you need.
Let's all be careful out there with our Stude's.
HTIH
JeffHTIH (Hope The Info Helps)
Jeff has given a good response to this.
When Larry first sent this item around, I immediately challenged the ten year part of it. Many cars more than ten years old came from the factory with extended life anti-freeze. I believe that some of this new stuff should not be used in Studebakers. It is the ten year rule that I strongly disagree with. I say to use the type that the car originally came with.Gary L.
I don't know about all the extended life coolants but DexCool definitely should not be used in vehicles where it wasn't a factory fill. DexCool doesn't mix with ethylene glycol coolants and creates a mess that causes clogs. GM had many headaches with DexCool due to lack of education to the consumer not to mix solutions and even techs who weren't properly schooled in the potential problems...particularly with aluminum engines and radiators. The mix would clog and cause blown head gaskets and radiators.
It seems after decades of people using coolants that are usually clearly marked that they're compatible with other coolants they stopped reading the warnings when DexCool was marketed or simply assumed compatibility and purchased and added less expensive ethylene glycol based coolants rather than DexCool.
For our older engines I'd stick with the tried and true ethylene glycol and leave the extended life coolants to cars which came with them originally.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
I'll say in all fairness that the modern 'Dexcool' types of antifreeze seem to be doing much better, I very rarely hear about ruined cooling systems in ca. 2004 up vehicles from any manufacturer.........and, the older cars/trucks also seem 'happier', even with the newer juice.--------------------------------------
I used to fill 55 gallon barrels with antifreeze at an auto parts store about 25 years ago. When we received the barrels we used a stencil and painted "permanent antifreeze" on the top of it before filling them. My boss told me that antifreeze does not break down with age. The reason you change it is due to rust that occurs inside an iron block engine and that a lot of the time people add water to a low system and have dilluted it too much.
