I have a knock at the rear of the engine. Thought it was the new exhaust system, then thought it was the starter motor. Sent it to a mechanic and while he had it in the air, checked the torque converter and says its loose. Is there a way to tighten the torque converter bolts without seperating the transmission from the engine?
tightening bolts on torque converter
Clutch / Torque Converter: tightening bolts on torque converter
Laisez le bon temps roulez avec un StudebakerTags: None
Originally posted by mjeansonne View PostI have a knock at the rear of the engine. Thought it was the new exhaust system, then thought it was the starter motor. Sent it to a mechanic and while he had it in the air, checked the torque converter and says its loose. Is there a way to tighten the torque converter bolts without seperating the transmission from the engine?
AllenLast edited by studebaker-R2-4-me; 03-04-2013, 04:14 PM.1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
The answer to your question is YES, by removing the cover on the lower half of the Converter Housing you can get to the Bolts in the Crank and in the Converter.
If they are not loose, it is a broken Flex Plate.
If you do not know if your Engine and Trans. are a factory matched (Dial Indicated) original pair, the Engine never having been replaced, you may need to Dial Indicate the Housing centerline to the Crankshaft centerline to prevent further problems.StudeRich
Thanks for the information. I completely rebuilt the engine last April. I replaced the flex plate. Used the same engine and transmission that was in the car when I bought it 7-8 years ago. Had a friend help me put the engine back in the car and can't remember who torqued the torque converter and whether we just "tightened" it. Thus the reason for figuring if we have to seperate the engine from the transmission. Yes, it could stil be a broken flex plate.Laisez le bon temps roulez avec un Studebaker
