1955 Champion, Victory Six. I have a weeping freeze plug that is behind the oil-fill tube. It would be an easy fix if I knew the secret of how to get that oil-fill tube out without destroying it. Help! How do I get this darned thing out?
How to remove oil-fill tube
Have not done this myself.......but have heard of people that put a tight fitting dowel down into the top of the fill tube, then put a couple of worm-drive stainless clamps around the outside of the tube (in the area where the dowel is inserted). Arrange the clamps so the worm drive areas are staggered, then use a hammer to tap upward on the worm drives.
Again, never did it myself (the flathead six engines I've done have been fully disassembled, so the tube got tapped out from the bottom (from inside the crankcase).Paul
Winston-Salem, NC
Some (like mine) have a wire retainer that then is attached to one of the oil pan bolts. It could be missed if the engine is caked with old oil and dirt
Originally posted by r1lark View PostHave not done this myself.......but have heard of people that put a tight fitting dowel down into the top of the fill tube, then put a couple of worm-drive stainless clamps around the outside of the tube (in the area where the dowel is inserted). Arrange the clamps so the worm drive areas are staggered, then use a hammer to tap upward on the worm drives.
Again, never did it myself (the flathead six engines I've done have been fully disassembled, so the tube got tapped out from the bottom (from inside the crankcase).Ron Dame
'63 Champ
I ended up having to tap mine out from underneath. If you REALLY don't want to mess with it get an expanding rubber plug (like this). You can put that in behind the fill tube.
This is one of the few things about the Champion engine that just seems pointlessly stupid. The location for the tube could have been moved less than two inches in either direction and the entire problem would have been avoided.
Nathan
I just took a slide hammer and pair of Vice-Grips.
Clamped them together onto the tube opening up top, and used the slide hammer to pop the tube out.
Used a chunk of 2x4 ad a dead blow block to tap it back in later on.
Didn't dent anything, or leave any marks on it.
Did it with the hood on, too (2R10)....
Took about 2 minutes.
HTIH
Originally posted by sactorandy View Post1955 Champion, Victory Six. I have a weeping freeze plug that is behind the oil-fill tube. It would be an easy fix if I knew the secret of how to get that oil-fill tube out without destroying it. Help! How do I get this darned thing out?HTIH (Hope The Info Helps)
Finally got it out.
Thanks guys. I finally got that tube out. The secret was a combination of penetrating oil and prying and twisting. I cleaned the area good with lacquer thinner and soaked it with penetrating oil for two days. Then I pried it from the block side with a crow bar. It moved just a little. I then used vise grips on the lower end to twist it back and forth. After a half hour of that it finally gave up and slipped out. there are a couple of scratches that I will file out and after paint it will be good as new.
Good work! Now be careful not to let water run into the hole when you pull the core plugs. Just be glad it is not the plug on the back of the block. I still have nightmares about that one.
Nathan
