I have discovered that the center steering arm hits the driver's side front of the oil pan on the 327 Chevy I am installing in my 62 Lark. I am using Chevybaker frame mounts and stock SBC motor mounts and a stock oil pan. I added 3/8" shims between the motor mounts and block but now the bolts on the bottom of the motor mount to the frame mount don't line up and would require further elongation to put the bolt in. In addition, I found it still hits at about 3/4 of the way to full turn.
I am now thinking I will have to remove the oil pan to "massage" it into shape. I am concerned about clearance to the crankshaft. Any thoughts, ideas or experiences before I lift the engine and remove the oil pan? Thanks.
