While we have the distributor out we notices the internal wires are bare in places and thought we would replace them. Any suggestions or words of wisdom?
Distributor rewire
If you have a GOOD parts store nearby, they should be able to give you pre-made replacements with the correct terminals and "limp" fine-strand wire. If you have to make your own, I've found old multimeter leads to work well.Originally posted by BubbaBear View PostWhile we have the distributor out we notices the internal wires are bare in places and thought we would replace them. Any suggestions or words of wisdom?
good luck
nate--
55 Commander Starlight
I really like the super flexible wire at:
http://www.robotmarketplace.com/prod...cessories.html .
I've seen improvised ground straps between the the two halves of the breaker plate, that immobilized the advance mechanism. I recommend running the ground through the distributor housing to a screw on the advance can. Keep the leads to the movable breaker plate long and flexable.
Mike M.
No luck at the auto parts. I'm sure I can find suitable wire. The terminals appear to be copper. Are they? Must I use copper replacements?Originally posted by N8N View PostIf you have a GOOD parts store nearby, they should be able to give you pre-made replacements with the correct terminals and "limp" fine-strand wire. If you have to make your own, I've found old multimeter leads to work well.
good luck
natesigpic
not sure, but regular sta-kons of the correct size/shape will be fine, those wires aren't subject to particularly high voltages or amperages. Just make sure, as someone else said, that the wire is flexible enough to not interfere with the movement of the breaker plate. What model distributor do you have? I bet rockauto sells 'em as well in case you just don't feel like rolling your own or don't have any questionable multimeter leads laying around.
nate--
It's a Delco-Remy in our 53 Commander. I've got another auto parts to try that's a little better on connectors. I may have some flag connectors that will work. I also think I can find some wire. I was mainly wondering if there was some trick or some special resistance wire used or something.sigpic
I just looked it up and they do not list anything for a '53 commander but for a '56 Sky Hawk they list a ECH LW42 for the ground wire and ECH LW60 for the primary, I believe the Delco dists. are all fairly similar over that year range. Best of course would be to pull the whole dist, or that wire, and take it in to the store with you when you go to pick it up so you can verify that it's right.Originally posted by laughinlark View PostNapa has the lead and ground wires you need. Get them to look them up in the catalog. Its been a while since I bought one, I think the # ECH LW40 will work. If your wire goes through the bottom of the dist? You have to slice the rubber grommet of the OE one and reuse it.
Gordon
good luck
nate--
Did a search on Google for 'Distributor points lead wire' and here's a good source listed....
Originally posted by BubbaBear View PostWhile we have the distributor out we notices the internal wires are bare in places and thought we would replace them. Any suggestions or words of wisdom?HTIH (Hope The Info Helps)
