Back Glass
  • Back Glass
    On my 51` it has a 2 piece back glass but I want a solid glass(I think they look better) How hard will it be to find one?
    Rob
    Rob,
    you might have to have one custom made, but check with Vic Phillips of Phillips Classic Glass, he advertises in the TW but here is his email and P# classicglass@semo.net 873-785-1927
      Rob, do you have a business coupe? Reason I ask is that it's the only 51 that had a two-piece rear window.
      As has been suggested (assuming this IS a Q-body), custom fab will be the ONLY way you have a glass made, shy of using plastic. [}]
      Miscreant adrift in
      the BerStuda Triangle
        Here is a glass company that can probally make you one. I have seen his work and it is good. They have the correct tint if you have tinted windows. Will be doing all my new glass for my 56 wagon. Reasonable, I think. Good Luck Vintage Glass, 480 Pike park Drive,Suite E, Lawrenceville,Ga. 30045 Greg Roberts 770-900-6363. www.vintageglass.com ,E-mail- vintageglass@hotmail.com
          My car is a 51` State Sedan. I have a 50` Land Cruiser that has a two piece rear glass, and I just assumed that my 51` would to.
          Rob
          1950 Land Cruiser
          1951 Commander State Sedan
            I HAVE SEEN AND REMOVED FROM CAR BOTH ONE AND TWO PIECE BACK GLASSES. I BELIEVE THE ONLY DIFFERNCE IS THE METAL STRIP IN THE CENTER THAT IS WELDED TO THE MAIN BODY. YOU PROBABLY COULD CUT THIS PART FROM A PARTS CAR AND WELD INTO A 1 PIECE BACK GLASS TYPE CAR PROVIDED YOU WERE ACCURATE WITH YOUR DIMENSIONS CENTERING UP METAL POST BEFORE WELDING.
              Your 51 will have a one-piece rear window.
              Miscreant adrift in
