Just wondering if anybody has any pics of floor pan repairs so I can get a better idea of how best to fix mine.Door seals are gone too.
Floor pans
What kind of pans and who was the supplier? There are no less than 2-3 manufacturers. It may make a difference when someone is giving the information you need. All pans are not created alike no matter what the seller specifies what they fit. Some are a bit universal fit looking and may fit into other cars as well as they fit a Stude. Some are much more refined than others. All are better than a street sign or cookie sheet. jimmijim
Stude Junkie+++++++Do it right the f$$$$ Time. Never mind. Just do it right. When youre done your done. You'll know it.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
I'm gonna be making them up myself with just some sheetmetal.I just wanted to get some ideas from some other ppl that have done it before.It'll be going in a 59 lark 6.Plus I'm kind of a tall guy and when I sit in the car I don't have alot of head room so I'm gonna drop the pans down about a inch or so just under the seat rails to help out.
Welcome to the forum hopsBB. Might be easier making it into a skytop although serving the same purpose but it would then be only a fair weather driver. Have fun and post pictures. Sounds very interesting what you may have planned. Sorta like the step down Hudsons. Let us know of future progress of your car. You might consider using a lower height seat but you probably are leaning more toward originality from what I gather[8D] jimmijim
Nice job, Brad. I used the CE panels and the pillar and frame supports, too. As Jimmmijim suggests, I hope I got it right the first time. Your installation doesn't have the "climatizer" opening, but they work fine with either situation. Dropping the floor is a novel idea but one may find some problems with the master cylinder, emergency brake routing, exhaust routing and that big cross member. Would love to see how it turns out.Dave Warren (Perry Mason by day, Perry Como by night)
So I shouldn't use all these free street signs I've been collecting?[B)]
Fred
quote:Originally posted by hopsBB
I had a friend use a yeild sign to patch his floor pan onetime,it worked pretty good too.
Yi haa!!
I have a 1965 IH pickup with plow that has some minor rust issues. Without the floor, the cab is unsupported and therefor it has dropped 3 inches and therefor the transfer case shift lever is stuck into the underside of the dash. Fortunately this has a hydraulic clutch so therefor there is no linkage to get out of whack. Unfortunately the master cylinder for the clutch is shared with the brakes (a single chamber with two push rods) and the brakes leaked and now the clutch doesnt disengage. Anyway, this is my project for this week. I will weld where I can but I will also use sheet metal screws or pop rivets for the floor pans. Good times! [8D]
Brent's rootbeer racer.
MN iron ore...it does your body good.sigpic
In the middle of MinneSTUDEa.
