My 1951 Champion hood cable handle came off - is there a glue that can fix this or do I need to start looking for a new cable? Also the hood doesn't want to pop up when the cable is pulled. Does that mean that something is out of adjustment where the hood pin meets the latch plate? The spring looks fine.
Hood Cable broke
First to fix the handle you may have to drill the end of the handle out, then slide it on to the end of the cable. Cross drill the handle with a tiny bit being sure to drill slightly into the metal end of the cable. Tap the handle where you cross drilled it and run a set screw in it. Then as for the hood I would first check hood and hood latch alignment.
PROUDLY MADE IN AMERICA
Here's a how-to from Chuck Collins on opening the hood.........
HEY, you're not Wilbur!Restorations by Skip Towne
