I didn't want to hijack the post on the oil pan seal and get it too far off topic, so responding here with a new post to discuss the issues brought up about my alum. timing gear and the flywheel bolts.
Here is the thread on the oil pan that started it, with the photos for reference:
That cam gear is probably at the very least 4-5 years old and most likely more about 8-10 years old as that was when this motor was first started to be put together by the original builder who supplied everything for it. I did not order it myself or put this motor together. So I don't know exactly when it was purchased, installed or where it came from at the time when we first started on this whole thing. But I have personally had the motor now for a couple years trying to work bugs out of it and I'm pretty sure the gear was put together with the motor originally close to 10 years ago at this point. So maybe is a good one, before the later possible problem ones?
Here are some more photos of the gear and the teeth. After the motor was originally put together, it was test run for about 5-10min just to see if it ran. So there are some wear marks on the gear from that as you can see here. It looks like they are fairly even across the teeth, so maybe that is a good sign, hopefully. Not seeing any chips or damage on it yet anyway. After I received the motor, other issues were found that eventually lead me to where I am now with it, basically the whole thing almost completely stripped back down and being rebuilt again, hopefully properly this time.
Same with the flywheel bolts, same deal, same timing. Those bolts are press fit in the crank, are not loose, will not come out by hand. Comparing them to other bolts I have, looks to me like they are the same as these grade 8 bolts, and are the fine threads. Looks like the bolts do have a bit of smooth shank that must be what is tight to the crank as the threads on the bolts are good, nuts thread on as needed. This would have been done by a machine shop, so assume were cut on a mill probably and looks like it, not just ground off by hand, so heat should not have been an issue. I've test fit the flywheel on there for length, didn't see any issues. Flywheel is for a manual shift trans, not auto. So unless there is some issue with this, I think it seems good?
