I have a blown head gasket and on my '48 Champion and have removed all the head bolts. What is a safe way to loosen the head from the block?
Head removal
It's just "crud stuck" seal which will let loose very easily.
Just tap it GENTLY with a rubber headed mallet while walking around the edge. Make sure you have it semi-secured, so it doesn't jump off the block. When it lets loose it will Un attach everywhere.
If it's really stubborn, you can slip a really thin putty knife between the head and block to "pop" the seal. Only have to go in about 3/4 inch with that.
DO NOT hit the head with anything metal (like a hammer unless you use a wood plate or block.
Make absolutely certain that you have that head checked for any cracks (with a Magnaflux/MPI test) warping, and have it surfaced flat at a machine shop before you reinstall it with a new gasket if necessary (and it will be)!
Here is a previous thread where we discussed the removal of my head on my 51 Champion, the inspection and reinstallation.
Champion Head Removal and Inspection - Studebaker Drivers Club Forum
PS. Buy a pair of long M14/1.25 Lug Bolts to put in two of the Spark Plug holes to handle the head with once you get it loose. It makes life a lot easier.Last edited by Big Dan; 07-12-2024, 11:17 AM.
- Likes 1
