Hello All---I finally got my 289 up and running on my home made test stand, and the Bill Hirsch exhaust manifold coating (supposedly the best) burnt of the first 30 minutes. I wiped them down very well with laquer thinner, as instructed. It could be that I should have sand blasted them before applying the paint. Has anyone had success with this product? Thanks ---BassMan
Bill Hirsch exhaust manifold Paint
Yes sand blasting is the best prep. don't they recommend Oven Baking them first?
I have had good luck with Duplicolor VHT 2000 Degree Ceramic, cast iron gray for the original look.StudeRich
For some time now I have been using Eastwood Manifold paint. I have some on my car that has been on there for over 30 years I paint the entire exhaust system with it and it holds up very well. I sandblast before application, and use two coats.
If the timing is retarded on start up and not corrected most any paint will burn off from the excess heat.
- Likes 1
Someone on the Forum recommended Rust-Oleum High Heat Ceramic Coating 2000 deg F and so that is what I bought (ordered on ebay, aluminum color). I haven't used it yet, but the recommended curing process is three cycles of heating and cooling. I'll have to do that in my kitchen oven. From the looks of the instructions it might be best to use a gas oven (to get the quick heating and cool-down times).
--Dwight
LOL! I'm not sure I'd put something with uncured paint in a gas oven that is heated by an open flame. Fumes.....BOOM! Also, be very careful subjecting cast iron to heating or cooling that is too abrupt or you'll crack it!
Big Dan, I see your point. I don't have a gas range anyway (& glad I don't). I'll have to use my electric range and do the best I can with the heating & cooling cycles. Being an electric the rise & fall in temp. won't be very severe or quick.
--Dwight
Shot blast cleaning is best; sand blasting a close second. If one wants to put time into it, light polishing with a die grinder/flap wheel/belt sander will help; the smoother the surface, the better the coating will adhere and hold tight.
Back in the day, there were ceramic coating shops which would give back a glass-smooth exhaust manifold which would last forever. Some of the classic V16s came with ceramic coated intake and exhaust manifolds. Anyone seen an advertisement for this service in Hemmings?
jack vines
Just as an alternative, you might consider having them professionally coated by "Jet Hot" coatings. I had my modified Champion Exhaust manifold coated by them (ceramic, I think) and it turned out fantastic. I think the shipping and coating were all under $250!
Here's their link: Ceramic Header & Exhaust Coating | Jet-Hot
And a picture of my manifold. My Champion Engine is mounted in a speedboat so it was important for me to get that cast manifold properly sealed up!3 Photos
- Likes 2
As another alternative you might consider Cerakote C-186 Piston coat. It is an insulating ceramic that will air dry or cure without "baking" in 5 days or so. looks great and will hold down under hood temps significantly when used on exhaust manifolds. I've had good luck with it. As with any application of this sort, prep is everything. I scrub down the part and then bead blast inside and out as I "paint" the inside and outside of the manifolds I've used this product on. Their website has lots of good info on this type of thing.
I will offer another recommendation for Jet Hot Coat. I did the manifolds for my Hawk during the restoration process. Now it is 6 or 7 years later and they still look like they did when I installed them.Wayne
"Trying to shed my CASO ways"
- Likes 1
The brown coating on the piston top is a heat barrier to hold more heat in the combustion chamber. The black coating on the skirt is an anti-friction coating. Most pistons today come with coated skirts. There are bare spots on each side of the skirt to measure the piston-to-bore clearance, but the coating essentially runs at zero clearance.
jack vinesPackardV8
Thanks for all your help---Sorry for the delayed response. We have been having internet connection problems. I read everyone's post. My powder coat guy is going to blast them for me and I will try again. I think was bad prep on my part. I think StudeRich is right on baking them. It's hard to get all of the oil out of them, and that might help. Thanks again---BassMan
Originally posted by BassMan View PostThanks for all your help---Sorry for the delayed response. We have been having internet connection problems. I read everyone's post. My powder coat guy is going to blast them for me and I will try again. I think was bad prep on my part. I think StudeRich is right on baking them. It's hard to get all of the oil out of them, and that might help. Thanks again---BassMan
