Hi everyone,
I have a rear main seal leak in my 259 engine that we finished rebuilding. Story is my dad started assembly including installing the rear main on engine 10 years ago. He passed away 3 years ago and I finished assembly on it recently. It has new pistons, rings, crank, bearings, etc, When I started it up it was leaking from rear main. I took it out (with engine in the car) by taking the cap off and then pushing the old seal out. It came out really easy. I put a new one in and it's leaking as well. I was watching a video that R1Lark created on you tube and he was talking about how some of the new seals don't have a snug fit. I am wondering if this is the reason it's leaking. He suggested putting a bit of RTV inside the seal. I was also watching the Jim Maxey videos and he put RTV on the inside of the new seal before installing it and installing the crank, and cap.
I would like to try using a bit of RTV on my seal and hopefully fix the leaking issue. My question is if I put some RTV on the inside of the seal and then install the seal by pushing it around the crank, will the RTV that I put in the seal get pushed out by the part of the block the seal sits on? Or will there be enough RTV in there after it's installed to make a tight fit? It won't be an issue with the cap because the seal will just slide on. This wouldn't be an issue if the crank has been removed but that's another can of worms I don't want to get into.
Thanks!
Steve
Thanks!
Steve
