I'm starting a new thread since the electrical issue with the fuel pump is resolved, and the thread is going into this direction. I cleaned the points and replaced the distributor cap, rotor, spark plugs, and spark plug wires (I got them all from Russ at studebakerparts.com) about 200 miles ago. In the last few weeks, I've noticed a lot of carbon/wet black moisture coming out of the tailpipe when I start the car in the morning. I pulled the plugs to take a look this morning and am attaching pictures.
None of them looked good; the first four look like the spark plug pictured in the cylinder 3 thumbnail. Numbers 5 and 6 look like the second picture. I think it may have a ring problem, but am not sure. I used a long rod to act like a stethoscope the other day when I heard a slight knocking noise at low RPM and traced the noise down to the 5/6 cylinder area in the lower block. When I first start it, there are some pretty good puffs of black/blue smoke and oily soot out of the tailpipe onto the driveway (pictures attached).
The engine is the infamous overhead 6. When I bought the car, the previous owner told me the engine had been rebuilt in 2015 after overheating and cracking the head going to a meet in Missouri. The car was used very sparingly since then and sat for long periods of time, so they may not have been aware of the issue. I have not run a compression test to determine if it's good, but the car pulls strongly when I drive it.
Known issues on the drivetrain at this point are; bad radiator (leaking from the lower tank), needs complete exhaust system replacement due to holes in muffler/rust, leaking front and rear seals (makes a foot-in-diameter puddle from rear seal) each time I use it. The rear channel on the front cross member catches oil from the front seal and, about once a month, fills it up to where it starts dripping. I think it may be time for an engine/transmission swap unless it just needs minor fixes.
The car needs to be reliable as it's our 2nd car and for the last year it's been down 90% of the time as each time I fix something, something else breaks. I've replaced too many parts on it to even think about replacing the car now. The front and rear suspension have been completely replaced. The brake system is all new with dual m/c and disc brakes up front. The rear axle was just rebuilt. The body and interior are just about flawless.
I'm beginning to think of a drivetrain swap at this point. The goal is decent reliability. It may be cheaper in the long run. I'm not a mechanic but I have learned a lot from the forum members and received a lot of sound advice. I'd like it to remain a full Stude, but I'm finding parts are getting to be a problem for normal maintenance items like fuel pumps, brake drums etc. I know I'm going to get screamed at for contemplating the McKinnon route, but it seems like if I want to use the car for what it was intended to be, I may need to go there.
