I am ready to install the KB hyper pistons in the 289 block, so reviewed KB recommendations for bore clearance and ring gap in "street - normally aspirated" engines. If <4.1" bore, piston clearance is to be .0015" to.002"; if >4.1", it is .002" to .0025". So the .002" I told the machinist was spot on, and I STILL cannot believe he suggested .0005".
RE ring gap, the top ring runs much hotter in KB hypers, so needs extra gap, which is calculated at bore inches X .0065". So the 3.6245" bore X .0065" = .024" gap. The 2nd ring runs cooler, about same as OEM cast pistons, and is calculated at bore inches X .004", so 3.6245" X .004" = .0145" gap (OEM Stude spec is .008" to .012"). Currently, the new rings have .012" gap when slipped into the cylinders, so looks like I have some "sizing" to do.
I decided to do this separate post on fitting pistons and rings, due to so many members reporting overheating problems with Stude rebuilds. Most pay a "professional" to do the work, but it's getting hard to find someone who'll even follow Stude Shop Manual procedures, let alone a special app, like fitting modern pistons in a Stude motor. So I suspect some of the botched Stude motor rebuilds are due to improper assembly; there are several pitfalls, and fitting hyper pistons has a few worth mentioning. Per KB, if their rings do not have sufficient end gap, they may "lock tight in the cylinder" and break the ring lands on the piston. I am sure, prior to that, the motor would likely run hot, and seem excessively tight, especially upon shut down (near instant stop), and when cranking during hot restarts. Maybe this post will help someone else down the road, come time for an engine rebuild.
