Tappet wrench size for 1950 Commander
  • Engine: Tappet wrench size for 1950 Commander
    Greetings from central Illinois. My 1950 Commander is needing a valve adjustment - but what size(s) tappet wrench do I need? I hate to buy an entire set if only one or two sizes are needed. Work room appears to be pretty tight, so I am guessing that a shorter wrench will be needed. Any words of wisdom for the job would be appreciated. Many thanks.
    Bruce
    1950 Commander
    3 spd/OD
    Just go to Harbor Freight and buy a set of combination wrenches. They are cheap but next time you need a wrench, you'll have it. It cost no more than purchasing two individual wrenches. They also sell 'stubby' wrench sets.
      I have always found that, if you have a 7/16", 1/2" and 9/16" Open end wrench, you can turn most of the fasteners anywhere on a Studebaker except quite Large ones like: Head Bolts, Main Bearing Bolts, Spring Shackle Bolts etc.
      Of course when space allows, it is always better to have a Box End or Socket handy for a better Grip.
        So far the only hex heads I've come across on any of my Studes larger than 3/4" has been the front crank bolt and spindle/axle nuts. Even a super cheap wrench set usually has sizes from 3/8" thru 3/4" by 1/16ths .
        Harbor Freight has some pretty nice wrench sets too, starting from $10 for a 9 piece set, or $14 for a 12 piece set containing both SAE and Metric stubby. AND, you can get 20% off this weekend for fathers day.
        PS: I have wrench sets ranging from really cheap 99 cent store stuff thru Craftsman (most of them), Crescent, Power-craft, Gearwrench, Proto, SK and Snap-On. The only one I ever managed to break was a Proto. Now; ratchets are another story. I haven't found one I couldn't break! Some last longer than others though.
          Tappet wrenches are thin so that you can hold the lifter with one and adjust with the other, then tighten the jam nut. A cheap set is about $25 at HF or on Amazon. It’s usually difficult or impossible with thicker standard open-end wrenches.
          Gary Ash
          Dartmouth, Mass.
          ’41 Commander Land Cruiser
          '48 M5
          '65 Wagonaire Commander
          '63 Wagonaire Standard
            simmobe2003
            I have a 1957 commander 6-245. It takes 2 1/2” wrenches to adjust the tappet clearance. Tappet wrenches or standard open end with the head ground down to make them thinner.
            Studebaker driver since 1971
            59 Lark
            59 4X4
            62 E45
            64 E15
            64 E35
              Basic truism: You never have enough tools!
                All,
                My '50 Commander 245.6 engine took 2 1/2 inch wrenches to adjust the valves, turns out that thin 'tappet' wrenches were not needed. Two normal open end 1/2 wrenches worked just fine. As an aside, I don't know how anyone could adjust those valves with the manifolds installed. With the manifolds removed the job was easy, but it would be a real challenge to do it with those manifolds in place.
                Bruce
