Hello all. I fired up my Avanti after it sat a long while and got the gift of coolant leaking out of the middle two core plugs on the sides of the block. No corrosion or holes, the leaks are at the seams. These were put in a couple years ago (appx. 25-50 miles driven since) by a mechanic I no longer use (for many reasons, like this issue). Before embarking on what looks to be a very straightforward procedure I thought it prudent to ask the braintrust here:
1) Is there is anything particular or special about changing core plugs on a Studebaker 289 vs. most other engines?
2) What size plugs are used on block sides? IE: Is it something I'll have to mail order, or is it common and I can get them at Autozone?
3) Is RTV or another thin sealant (like Pioneer Core Plug Sealant) recommended, or is dry better for some reason?
4) Installation depth? Seems that some prefer to hammer flush with the block, others to the depth of the bevel.
5) Do I need to drain the coolant before removing the plugs, or is there only a bit of coolant in the block at these areas?
