I bought a set of Bilstein shocks for my ‘63 Hawk. I have encountered an unexpected mounting problem with the rears, part number BSN-24-001564. In the past, with cheaper shocks, I have cut off the ends of the top crossbar to allow the mounting bolt used on Studebaker rear shocks to pass through the rubber bushing and put washers on each side of the bushing to keep the shock centered. Much to my surprise, the top bar on these Bilsteins is solid, not a tube with flattened ends. I have found it almost impossible to press out the crossbar on the Bilstein shock absorbers. I finally got one of them out but some of the rubber bushing came out with it. It acts like the rubber is seriously bonded to the crossbar. I am able to easily press in the spacer tube from the old Studebaker shock now that the Bilstein crossbar is removed, but I can tell that the fit is loose enough that the new shock will not stay centered. I plan to put washers on each side of the bushing to keep it centered. This has been a frustrating experience that I wouldn’t wish on anyone. Unless some of you know of an easier way to get this job done, I suggest that anyone wanting good shocks for their Studebaker select another brand!
I did try drilling a 7/16” hole through the metal crossbar after I cut off the ends. The metal is quite hard. I managed to ruin several drill bits before giving up on that idea.
Actually, I really like Bilstein shocks. I put them on my Ford pickup and they greatly improved the ride. I am sure they will be a big improvement on the Hawk as well, when I am finally able to install them.
Dale
Dale
