I have been having the occasional "catch" when starting my 259 Y6 with AT x 2 years now. I have a fresh battery, a good charging generator & regulator, and now a freshly rebuilt starter with 3 bushings and a quality rebuild. Not to mention cleaning to shine all connections in the starting circuit. I have come to the conclusion that I have either an ignition switch issue or bad TC gear teeth. The teeth on the Bendix gear had mild wear when I rebuilt it last month.
My ignition switch operates nicely without any issue in any position and without any wobble to the inserted key.
I have 2 used torque converters that I removed from 2 cars that are in the shed x 5-10 years. If the worst happens and I need to replace the TC, can I simply install and fill the system complete with new AT fluid or will it require additional attention beforehand ??
