Does anyone know the size (thickness) of the clutch adjustment rod in the above two cars?
Clutch adjustment rod........Lark and Avanti
Tags: None
These rods are notorious for bending, especially if you are running a heavy-duty clutch. The line of thrust does not pass straight down the axis of the rod, so there is always a bending moment. You can easily make an improved replacement by getting two shift rod clevises (as used on the lower end of the shift rods on all column-shift cars), and a short piece of fine threaded rod. Two clevis pins and two 3/8 NF lock nuts complete the picture. This puts the thrust line straight down the axis of the rod, and the whole assembly is stouter. And costs you about $zero, if you have a parts bin.Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by gordr View PostThese rods are notorious for bending, especially if you are running a heavy-duty clutch. The line of thrust does not pass straight down the axis of the rod, so there is always a bending moment. You can easily make an improved replacement by getting two shift rod clevises (as used on the lower end of the shift rods on all column-shift cars), and a short piece of fine threaded rod. Two clevis pins and two 3/8 NF lock nuts complete the picture. This puts the thrust line straight down the axis of the rod, and the whole assembly is stouter. And costs you about $zero, if you have a parts bin.
