So, when last we talked (before Clark blew up the internet - LOL) we were discussing the installation experience all of you have with 12-volt alternators on your Champion Motors. Thanks for all your responses and please feel free to repost them.
For the purpose of helping out those who may follow, I want to repost this with the info and results the process handed me. I wanted something 12- volt for adequate charge, but also something that looked original.
I came across the "Powermaster" 82112 90 amp "one wire" alternator that advertised a bolt in fit - I was skeptical. They are available at Amazon via JEGS. (if you search Google or Amazon just type in "Alternator 82112"). They are Made in America (West Chicago, IL). There is also a Powermaster 82112-2. The difference is that the -2 has a post to direct wire a "BATT" light. The base 82112 doesn't have that
First, those come with a 3/8 " pulley. So I called Powermaster and talked to Ed (630) 957-4019 x222. VERY HELPFUL AND KNOWS HIS STUFF! He had a 5/8" pulley for the alternator and when I measured my crankshaft and water pump pulleys they were actually 5/8 as well. An 11/16 belt rides a little high in the groove of all three pulleys ( 11/16 to 1954 when I think Studebaker went with the 3/8 pulleys). So I ordered a Powermaster PMW-1135 5/8" pulley from Summit (search "PMW-1135" at Summit).
OF NOTE is that the Powermaster Alternator comes standard with a .699"/17mm shaft which was standard on just about every American (Delco, Autolite, etc) generator and alternator made INCLUDING the Autolite Generator on our Champions. So, if you order one of these alternators you can use the pulley off you old generator - if you have it.
Also NOTE the mounting tabs on the alternator are 6.68" inside edge to inside edge and should fit the stock '51 mounting bracket perfectly (about 6.65 give or take a coat of paint).
I bought a NAPA NBH-2522397 Belt designated for the stock Champion Set-up.
Now, the big question was how good the fit would be, and how much shimming I'd have to do to make it fit right. The answer - ABSOLUTELY NONE! The Alternator looked very close to the original generator (which I didn't get with the motor) and the fit in my (1951) Champion Generator Bracket was PERFECT. Alignment of the pulley was PERFECT! No adjustments necessary! Honestly, I was shocked!
So, it looks original and will provide 90 amps for my 12 volt system. Here's some pictures!
Would love any comments,
Big Dan
PS. I just noticed in the pictures I forgot to go back and tighten up the mounting bolts. What an idiot! LOL!
Big Dan
