I'm aware this topic has been discussed before but not like this.
I'm at a standstill with my ignition because I can't find the specs I need and so can't make sense of which one to use.
Regardless of what car or application. I'm hunting for parts no longer available so matching specs is the best I can do. What is holding me up is an understanding of the ohms ratings of the ballast/ignition resistors. Some are rated at 0.4, 0.6, 0.8 ohm and others at 1.6, 1.8 ohms etc... Others say they are variable 0.75-1.5 ohms. Not many, and I mean none I can find, give a cold and hot value and watts ratting like the Mallory 700 I'm trying to replace. As all of my ignition is Mallory I have been advised not to mix and match. Best to stay within the parameters set by the manufacturer and hopefully no electrical glitches will result.
Coils are of the two main types internally wound to give 1.5 ohms or 0.6 ohms or there abouts. My coil Mallory 29150, high output low resistance coil in the 0.6 ohm range. is approved by Mallory to use with all of there ignition systems, from points, points replacements to transistorized and CD ignitions. It is not internally wound to give the 1.5 resistance to negate the use of a ballast resistor so it is recommended to use the Mallory 700, with 0.75-1.5 ohm variable resistance.
I believe I need a 3.0 ohm resistance system to run the engine properly on points or optical trigger.
Holley/MSD want to sell the MSD 8214 resistor as a replacement but where are the specs? 0.8 ohm is all that is mentioned. Apart from it being recommended to use with there Blaster 0.6 ohm coils. Others just give one value. Is that hot or cold?
I have read that I could use any but that doesn't seems right. If I could use any then why so many different numbers?
The system:
Running in a 59 Lark with no resistance wire.
Delco window style distributor with Mallory e-spark points replacement.
Mallory 29150 electronic coil.
Mallory 28371 circuit guard module.
Just need the ballast resistor. A Mallory 700 or equivalent.
Any help or education would be appreciated. Please, I need some numbers or a detailed explanation as to why I shouldn't care?
Thanks.
P.S. If you want to know how I ran it before I had a Mallory 6AL hooked up and therefore did not require a ballast resistor. Now I do.
The system:
Thanks.
