1945 US6 Hercules JXD 320 CID Flathead Six Motor
  • Engine: 1945 US6 Hercules JXD 320 CID Flathead Six Motor
    It looks like we are stuck here in BC for yet another winter due to our government continuing to close the border with the USA.
    I have pressed my 1945 US6 into service ( 10 Wheel Drive with chains on front tandems) as a massive snow plow one half mile up our mountain driveway.
    My question for all you lubrication experts is this: After purchasing 20+ years ago, I performed an oil and filter change using 30W Non-Detergent oil as I felt that was probably what was originally used. When cold it does take longer than I like to build oil pressure. It is time for a full service before winter hits again.
    What viscosity (it gets cold here) would you recommend and what type of oil would be most suitable? I have a good supply of Diesel 15w40 -Would this be appropriate?
    Thanks for any expertise you can offer.
    Cheers,
    Bill Click image for larger version
ID:	1912756 It should be pretty obvious why I have traditionally spent our winters in Arizona.
    Thanks for sharing your wonderful Studebaker-related machine with us. But, a so-called lubrication expert in one region might not be as "expert" as one who lives near you in the north where "real" winter is a given. You might make a friend with some local fleet maintenance mechanic in charge of vehicles that absolutely must perform in the frozen winters of the north. Most folks where I live would have a problem recognizing the plug-in for a block heater, let alone contemplating having to warm up oil or fuel to get an engine to turn over and start.
      Depending on the what the expected ambient temps you're going to be running it in (I presume winter), I would pick either a 10W-30 or 5W-30 (latter if you're going to be starting below 0 degrees F and staying below about 60 deg F. 10W-40 or 15w-40 would acceptable down to 15 degrees or so. I've never used non-detergent oil in a combustion engine.
      And yes. I grew up in Northwestern Montana, so am used to low temperatures.
      Whirling dervish of misinformation.
        Thanks for your insight John. I contacted my local lubricant wholesaler and he in turn contacted his supplier who endorsed 10W30 full detergent oil for my application.
        Cheers, Bill
          Don't use diesel oil unless it says for diesel and gas. Diesel only oil(type3?) will gum up from gasoline fumes.
          1936 Dictator
          1950 Champion Regal 4 dr parts car
          1953 Commander Regal HT
          1953 2R5 Pickup
          1947 M16 Truck
          1949 2R16 Truck
          1960 Lark VIII Convertible
          1960 Champ 5E7 step side short box
          1962 Champ 7E5 no box
          1962 GT Hawk
          1963 Lark VI 4 dr
          1963 GT Hawk R2
          1964 Daytona Convertible
          1964 Commander Wagonaire
          “America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham Lincoln​
