Rod bearings from my engine
I would definitely replace them and plasi-gage to see what clearance you have. I would like to see .002 to .0025. Are they standard bearings now ? How are the main bearings ? I assume the engine is out of the car ? The problem is, if any are out of spec you are talking a reground crank with new rod and main bearings. For me, most engine refresh turns into a complete overhaul.
- Likes 1
Originally posted by 62 Lark View PostI would definitely replace them and plasi-gage to see what clearance you have. I would like to see .002 to .0025. Are they standard bearings now ? How are the main bearings ? I assume the engine is out of the car ? The problem is, if any are out of spec you are talking a reground crank with new rod and main bearings. For me, most engine refresh turns into a complete overhaul.
Having said that, with no more miles or hard use than hobby cars get these days, a patch job can suffice. But then there are the valves and the valve guides and the cam and the rocker shafts and yes, pretty soon it's an overhaul.
jack vines
- Likes 1
X2 - if you can see the copper plating, the crank usually has some wear also.
jack vines
Thanks for the input.Mike and Dawn
'61 Champ
The crankshaft where the rod bears are, running a finger nail across them, tiny grooves can be felt.
Thanks again.
Mike and Dawn
'61 Champ
You could also mic the crank to see how worn it is. If those are standard bearings, .001 and/or .002 bearings may be available.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
- Likes 1
Good Morning, If you are feeling grooves with your fingernail there is wear on the crank. It's a lot of work to R&R an engine and then only replace the rod bearings. That said, your project, your budget. Not trying to be snarky.
- Likes 1
The forward rod bearings (#1 and 2) will have the worst wear. Which number are the ones in your pic from? If from #7 and 8, I'd be worried. If #1 and 2, I'd polish the crank and install new bearings. Grooves in any crank with over 500 miles are not unusual; vertical grooves (running in line with rotation) that do not, "catch" the fingernail are OK, but horizontal grooves (that run across rotation) are a no-no. As for your goals and expectations of 5000 miles, you may be amazed at how long that motor will last!
Originally posted by JoeHall View PostThe forward rod bearings (#1 and 2) will have the worst wear. Which number are the ones in your pic from? If from #7 and 8, I'd be worried. If #1 and 2, I'd polish the crank and install new bearings. Grooves in any crank with over 500 miles are not unusual; vertical grooves (running in line with rotation) that do not, "catch" the fingernail are OK, but horizontal grooves (that run across rotation) are a no-no. As for your goals and expectations of 5000 miles, you may be amazed at how long that motor will last!
Thanks.Mike and Dawn
'61 Champ
