Had some members at the last club meeting ask about a front hub installer and as I had one said sure anyone that needed it could borrow it. Well guess what my Mac hub installer doesn't fit a Studebaker. So called Myers Studebaker parts and he had a extra front crankshaft bolt so had one sent and building an adapter to fit the Studebaker crank. Welded a 1/2"stud to the Studebaker bolt with the right treads to screw into the adapter and now just need to cut down the head of the bolt so it clears the center of the hub and may need a small spacer to take up the extra length and I think we have a hub installer everyone can use when needed.
Studebaker crankshaft hub installer
Phil Harris at Fairborn Studebaker sells one that uses a thrust bearing to keep things straight and smooth.HTIH (Hope The Info Helps)
My brother, Bill, was working on my '55 a couple years ago and needed one of these tools. Being a machinist he just pulled out a length of pipe and some other assorted stuff and started cutting and welding. Wallah! In about 15 minutes he had a really cool tool to pull the harmonic balancer. I should ask him if he kept that tool. I suspect he did as he has a '57 Golden Hawk and might need to use it on that some day.
Ed Sallia
Dundee, OR
Sol Lucet Omnibus
This is to install the hub once you have removed it and need to put it back on. My Mac tool looks a lot like the one in post #6 just a little fancier. It uses different adapters on the crankshaft end so it fits different shafts. There is no adapter with a shaft tread of 11/16 x 16 which is what fits a Studebaker so this is what I had to build up.
my friend is a machinist. Helped me with the bolt. Then I use big washers, pipe nipple and a used king pin thrust bearing.sigpic
Claude Chmielewski
Studeski
http://www.studeski.com
Fillmore, Wisconsin
47 M-16 Truck
53 Commander Regal HT
53 2R5
60 Lark VIII Convertible
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
63 Lark VI parts car
63 GT Hawk R2 4 speed
64 Commander Wagonaire
64 Daytona Convertible
50 Champion Regal (parts car)
36 Dictator
36 Dictator in pieces
