I've just had something kinda weird happen to 2 Studebakers. I've been driving a friend's '50 Champion around (to cruises, etc.) and one day I shut it off and when I tried to start it all I got was a loud click. I guessed low battery and asked a couple of friends to push it so I could 'pop the clutch' and start it. It would not start, acted like the engine was locked up. I had it flatbedded home. I tried turning the engine with a large ratchet and a 4 foot jack handle. It would not turn, but when I turned it backwards, there was a loud click and suddenly it turned. I put the key in and it started! I guessed that the starter somehow got 'locked' into the flywheel ring gear and released when I turned the engine backwards. It has not happened again.
A week or so later, I went to start my '53 Commander. It hadn't been used for a while (a few weeks) so it cranked a bit and didn't start. I cranked it some again and stopped to pump the gas pedal. When I tried to start it, it acted like the Champion had; a loud click and no action. I walked away and a couple of days later tried to turn the engine using the crank bolt and the same large ratchet; no luck, stuck tight. I tried turning it backwards and the crank nut simply loosened. Today, I took the starter off (a desperation guess) and as I removed it I heard a familiar 'click' (like the Champion). I tested the starter with a battery and it worked fine, so I re-installed it. The Commander started with no difficulty! Is this weird or what?? Anyone else experienced anything similar?
