I am assembling my suspension A frames and the rubber grease seals want to squeze out when I tighten the bushings / grease caps. Yes, I have spread the outer ends about .015.I know they should have alittle crush to them, but not this much.Do I need to take alittle off the bushings? Any thoughts?
Thanks!
'64 R2 back on da road again
POCI,SCCA,SIMTA
Thanks!
POCI,SCCA,SIMTA
If it's happening on the lower pin bushings, it has to do with the pin not being centered in the bushings. Since there is no provision for rotating the lower pins once they've been installed (they don't relate to alignment and are staked to the lower steering knuckle supports), the bushings must be tightened evenly during installation.
