The threads are stripped on my oil filter mount. What's the best fix?
Oil filter problem
The spin-on Oil Filter Bases come in two types, the 1958 to Early 1962 partial flow Type, and the Late '62 to '64 full flow type. To buy one you need to know which you have.
Originally posted by StudeRich View PostThe spin-on Oil Filter Bases come in two types, the 1958 to Early 1962 partial flow Type, and the Late '62 to '64 full flow type. To buy one you need to know which you have.
http://studebakervendors.com
I do not know what threads he is referring to (or how it happened). The solution is still to buy new parts.Gary L.
Your filter is a Fram and uses a C4 cartridge. I agree with Rich, it's really tough to destroy the thread in the center tube unless it is somehow cross threaded. If the filter housing is damaged beyond repair, someone here should have a good used one for sale. Bud
Originally posted by StudeRich View PostOPPS, found his Car, a '56 Sky Hawk and it's Engine Pic:
[ATTACH=CONFIG]83334[/ATTACH]Brad Johnson,
'56 Sky Hawk in process
Originally posted by plee4139 View PostThe threads are stripped on my oil filter mount.(?) What's the best fix?John Clary
Originally posted by jclary View Post... the mount is the bracket assembly that attaches the filter unit to the oil fill tube. Stripped mount would simply be bolts & nuts...right?Brad Johnson,
Not every car out there is exactly the way it was built 60+ years later. It’s possible that Peter’s Hawk has the later spin on filter with the aluminum base and that’s what has stripped out.
Either way.. Figure out what you have and what you need and call up your favorite Studebaker vendor and order one. Parts aren’t hard to find.
